Question about Garden
Grass catcher My Honda Model HRR2166VXA (with grass catcher attached) blows most of the grass up and back into my face when I mow. The catcher is attached correctly. Any suggestions?
  • 11 Answers
SOURCE: lawnboy 10301 won't start
you need spark, gas and timing to make it run. have you checked spark? sounds like you are getting gas. did you hit anything hard with the blade while mowing? this can throw it out of time.
Posted on May 23, 2009
mowerman1857
  • 389 Answers
SOURCE: I can't find a grass catcher attachment for my
Hello, I did finally locate your model number in my Electrolux Home Products catalog, HOWEVER, the bag is no longer manufactured and as near as I can tell, there are no longer any available to purchase. You can still buy the frame and hard plastic top but no bag.
This is a 1995 model so this is not an uncommon thing.
I can look up the part numbers of the available items for you if you want them.
Sorry I could not present you with better news.
Chuck
Posted on Nov 04, 2009
  • 15 Answers
SOURCE: I have a Honda mower model HRR2163TDA but it
Your piston oil rig may be bad and is alowing oil by wich will fowl the plug. The more load on the engine such as a full bag the more oil gets by.
Posted on Apr 22, 2010
  • 333 Answers
SOURCE: Rear mounting grass catcher has space along bottom
grass will build up over time on the underside of the deck possibly impairing the flow of the clippings. I use a flat screwdriver to scrape the big clumps of grass off the underside.
Posted on Jun 16, 2010
gemyr2
  • 63 Answers
SOURCE: my B&S motor GMC mower that i found on the
YOU HAVE A LINKAGE THAT CAME LOOSE FROM THE CARBURATOR TO THE THOTTLE LEVER. CHECK THAT AREA AND RECONNECT.
Posted on Feb 20, 2011
Troy Bilt self propelled walk behind...grass goes everywhere!!
Mine works,great,take bag off and it will mulch it and look like it's being bagged up.Is your grass knee high?Do you have it low enough?Here's your manual,read the part on grass catcher and see if your doing something wrong,make sure grass door is open.Check your blade to make sure they didn't put it on upside down.The cut part should be facing out. http://pdf.lowes.com/operatingguides/043033566280_oper.pdf
Jul 21, 2017 | Troy Garden
How do I attach the grass catcher to my push mower?
model number and photos of what you got now????
Jul 02, 2015 | Garden
Catcher parts
Get model no. of mower. You can order flap on line or at mower repair shop. I have mine on back order now.
Jun 24, 2013 | Poulan Garden
Wierd grass catcher problem
There are a couple of causes for this. Is the blade height the same on the new mower? Higher blade height could cause a lot of the grass to be blown out from under the deck, and not into the catcher chute.
On the trailing edge of the mower blades is a small 'wing' for lack of a better term. There are two types of blades, mulching blades that have a lower 'wing', while catcher blades that have a slightly higher 'wing' but it makes a difference.
If the season has been hot lately, the grass may not be growing as fast, hence less clippings, and less dense grass could also cause this.
Jun 16, 2012 | Mtd Garden
After emptying the grass from the storage on the back of the rider, when I start to mow again, the grass that is in the catcher from the deck to where it shoots out, gets clogged and will not move on to...
Clean out your chute also and don't let the catcher get so filled up, check it for readiness to empty more often.Don't cut wet grass that tend to stick and cause trouble. Good Luck...709
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a Honda mower model HRR2163TDA but it doesn't seem to matter what mower I own because I end up with the same problem. After about two years the spark plug gets fowled ''black'' quickly every time I...
Apr 18, 2010 | Garden
I have a MTD garden tractor with 3 bag catcher and the shute constantly plugs up. I mow once a week but it's like there isn't enough vaccum to blow the grass into the bags. I have my blades with the bent...
bent part of the blades need to be facing up towards your deck which creates a vacuum and allows a better lift to throw the grass in the bag When bagging blades should be labeled as high lift blades which are designed for bagging . Also which you probably already know its better to bag when the grass is NOT damp.
Hope this helps your issue
Jun 04, 2009 | Mtd Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
