Toshiba ct 90367
Why is the closed captioning button not working?
3 Suggested Answers
  • 162 Answers
SOURCE: Toshiba ct-90367 complete manual
http://www.google.com/url?sa=t&rct=j&q=ct-90367%20complete%20manual&source=web&cd=1&ved=0CB4QFjAA&url=http%3A%2F%2Fa248.e.akamai.net%2Fpix.crutchfield.com%2FManuals%2F052%2F05242TL515.PDF&ei=V-r9TtimAery0gGjv7SKBw&usg=AFQjCNG3nkTI5PH4e5nuzFIYk4ifhwmS1A
Posted on Dec 30, 2011
gopakumarg43
  • 74666 Answers
SOURCE: toshiba 27AF44 closed caption
It will be so related to universal remote controls. All buttons won't work with what it should be meant for. The only thing we can try, is to try an other setup code. Try that.
Posted on Jul 03, 2012
How do I get the T.V back to full screen?
Look for a aspect button on the original remote or if using a box for signal look on its remote also.
Dec 13, 2012 | Toshiba CT-90367 Remote Control 75023297
Dec 30, 2011 | Televison & Video
Black square comes on tv
hi,
in your tv the closed caption option is in on position. make it off o run out the black square.
to make the closed caption (cc) off. do the following.
1. press the menu button
2. select setup
3 go to closed caption (cc)
4. select closed caption mute (cc mute)
ok
Jan 27, 2011 | Panasonic CT-36D32 36" TV
Can't find closed caption
I believe page #48 on this link will help, though I am unsure of the type of tv you have. I can only say that I hope this helps. If not, you could try to google your tv and see if you can find an online manual that tells you how to turn on the CC feature. Good luck! Sincerely, Der Strom
Apr 13, 2010 | Toshiba CT-90159 Remote Control
The Cap/Text button works but it makes no difference on my tv
Try new batteries in the remote and confirm that the settings are correct and that you haven't accidently selected no caption option.
Sep 04, 2017 | Toshiba CT-90157 Remote Control
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
Jul 09, 2008 | Toshiba 57H82 57" Rear Projection...
I have a Toshia TV - Model 19A24 - Made in Thailand - Dated Nov. 2004 # 7961C2877 A. With it, I have your manual control unit: CT-859. I accidentally pressed "menu" on the control unit. ...
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
Jun 02, 2008 | Toshiba Televison & Video
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Remote control users manual needed
I had this problem just now for the Toshiba DC-SB1 remote control model, and I think the problem might be that you're pressing the wrong button. Try pressing the "skip track" button right below where it says close caption on the remote. It's deceiving because, based on where the words 'closed caption' are, it looks as if the stop button is associated with it, but it's not. That's what I was doing wrong, it may be a different problem for you though.
Dec 11, 2007 | Toshiba MD19N1 19 in. TV/DVD Combo
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
