Give 5 examples of cline words - Office Equipment & Supplies
What is the definition of an suffix and a prefix i would like to know about it please give me information from the dictionary?
Prefixes and suffixes are grammatical and lingual "affixes." Prefixes are affixed before and suffixes after a base word or word stem to add information. For example, with the word "prehistoric," the prefix is "pre-" meaning "before," the base word is "history" meaning "recorded events and knowledge", and the suffix is "-ic" meaning "relating to the science of."
In other words, "prefix" simply refers to an attachment before or in front of, in this case, a shorter word or stem. In lingual terms, a "stem" is the main part of a word to which prefixes and suffixes can be added and may not necessarily be a word itself, such as "dod" in "doddle."
Similarly, "suffix" refers to an attachment after the end of an existing word or stem, serving to form a new word or functioning as an inflectional ending, for example, "s" or "es" to make for plurality.
Sep 30, 2014 | Games
On firefox can't open my email it says untrusted
Pls.check your system date & time is correct ???
Pls Try to correct your systems Date & time on the extreme right corner of your screen.
after change date & time it corrected.
if Problem comes again with Date & Time you need to replace BIOS / Motherboard Battery.
How to change date & time
Option 1>>>
Open the command prompt:
  • Click Start.
  • Type "command prompt."
  • In the results, click on Command Prompt
  • Type the word "time". Type a space, and enter the new time in the following format:
    • HH:MM:SS AM/PM. For example, time 5:34:00 PM, time 12:15:00 AM, etc.
    • Press enter or return.
Type the word "date". Type a space, then enter the new date in the following format:
  • MM/DD/YYYY. For example, date 5/15/2009, date 2/14/1999, etc.
Option 2>>>
  1. 1Open the command prompt:
    • Click the Start button.
    • Click on All Programs.
    • Click Accessories.
    • Click Command Prompt.
  2. 2Type the word "time". Type a space, and enter the new time in the following format:
  3. 3Type the word "date". Type a space, then enter the new date in the following format:
  4. 4Check the clock in the bottom-right hand corner. The time should be successfully change.
Sep 02, 2014 | Google Computers & Internet
Can you give me examples of abstact nouns
Abstract nouns are things that cannot be experienced with the five senses.Things such as: Compassion, courage, intelligence, and laughter.Good examples are listed : http://examples.yourdictionary.com/examples-of-abstract-nouns.html
Aug 28, 2014 | Healthy Learning Relational Aggression:...
Examples cline words
Freezing, frosty, cold, warm, hot, sizzling, steaming, boiling
Jun 20, 2013 | Computers & Internet
What is a tripule
Triple means 3 times as much. Example 15 is the triple of 5 because 15=5*3.
There is also the word TRIPLET which means a collection (ordered or not ordered) of three quantities or objects. When doing coordinate geometry in space you locate a point by giving its three coordinates (x,y,z). The collection of three numbers (x,y,z) is a triplet.
Apr 08, 2013 | The Learning Company Achieve! Math &...
What are the special nouns?
Special nouns are abstract nouns like names of qualities,emotions or ideas which can only be experienced and not physically seen,touched etc
example bravery,honesty,integrity etc
Aug 04, 2011 | Macromedia Computers & Internet
Give examples of noun derivative
noun derivative - a verb that becomes a noun by adding a suffix.
You sometimes come across words which have been derived from their roots by adding certain structures like prefixes and suffixes.
In your earlier years of schooling, you must have been done with exercises and development activities on the use of prefixes
A prefix- is a group of letters added before a word or base to alter its meaning and form a new word. In contrast, a suffix is a group of letters added after a word or base.
5 Example of prefixes:
Prefixes MEANING EXAMPLES
ana- up, back, again analogy, anatomy, anagram
anti- against antipathy, antiwar, antisocial
apo- from, away from apology, apologize
com- with, together communal, community
con- with, together connect, confide conspire
there are so many example of this. i hope it helps. remember that an adjective derivative is a noun, verb and adjective that becomes an adjective by means of adding affixes.
In this lesson, you will deal with deriving words through the use of suffixes.
A suffix added to the end of a root word.
5 Example of suffixes:
Suffixes Meaning Example
-ics things having to do with optics, physics
-ism the belief in pacifism, terrorism, socialism, communism
-logy study field of biology, geology, etymology, cardiology
-or, -er one who takes part in doctor, actor, teacher, driver
-sis act, state, condition of analysis
We have, for example, a verb that becomes a noun by adding a suffix.
This is called a noun derivative
A noun that becomes an adjective by adding a suffix is called an adjective derivative
Example of Adjective Derivative:
subject- subjective
addict- addictive
react- reactive
success- successive
care- careless
ugly- ugliness
hope- hopeless
steel- steely
accept- acceptable
obey - obedient
These are but few ways by which we can identify how words are derived.
Jun 13, 2011 | Macromedia Computers & Internet
How to clean print heads on a epson stylus T24 bobsplace222@msn.com
you can fire with sering with ip or water and if it is fire then give one head clining and printer put on for 3 hours
Mar 05, 2011 | Epson Office Equipment & Supplies
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
907 people viewed this question
k24674
