Question about Dell Latitude C640 Notebook
Red vertical lines appear, can only run computer in Safe Mode
Model: Dell Latitude C840 When I turn on the computer, white underscore lines appear across a page that indicates to select to enter in Safe Mode. I didn't click anything, so it automatically goes to start in regular mode. Windows XP attempts to open (has green vertical bars that appear as it is trying to load). Then a blue page flashes briefly saying something like "sorry for the inconvenience..." and then the screen goes black. Then, after about 5 minutes, the computer does this all over again. When I select to run in Safe Mode, Windows XP loads, and I can access my files, but the screen has lines across it (it is also made worse when I press on certain parts of the laptop). Any ideas? I'm thinking it could be the video card. Any suggestions? Thanks
  • Anonymous May 23, 2009
    Your Fagoot
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
Check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Posted on Aug 27, 2007
SOURCE:
What do I do when the used dell latitude c840 i received has just a white screen when I power it on?
might be a bad lcd or try to reseat the lcd cable on both ends on the motherboard and behind the lcd
May 14, 2014 | Dell Latitude C840 Notebook
CAN A DELL LATITUDE C840 BE BOOTED FROM ITS USB
power laptop on then pressing F12 and the Boot Device Menu appears
if usb is not an option on the list you cannot do it
Jan 27, 2014 | Dell Latitude C840 Notebook
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
Reset password bios c840 dell latitude
Remove the CMOS battery from the motherboard.
Jan 03, 2010 | Dell Latitude C840 Notebook
I accidentally disabled the screen
try booting in safe mode and do system restore up to the last good working date of your laptop. . .
hope this helps.
Oct 27, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
No sound on my dell latitude c840
maybe it is your Bios. what you should do is download a software call WINPHLASH, and try flash your Bios. are you could try and update your driver. by using driver detective.
May 31, 2009 | Dell Latitude C840 Notebook
Boot problem
sounds like a bad driver-can you boot into safe mode? how about the bios?
Apr 09, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Thin vertical lines on screen
You need a new LCD screen.
Thats a common problem with those panels
Or can be a hardware defect that occurs when the screen wasn't properly tested at the factroy
Nov 23, 2008 | Dell XPS One All-in-One TV Desktop with...
Cd-rom
i have a del latitude c840 and no work ,cd,dvd modem,so i need a configuration complete. ps.excuseme i not speak inglish
. thanks.
Apr 15, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Latitude C640 Notebook Logo
513 people viewed this question
Ekse
Clive
Clive
