Question about Frigidaire ATF6000ES Front Load Washer
Limited wash setting selections
I just plugged in my brand new washer. It will only select the "Delicate" and "handwash" settings but none of the others. These settings work, but I would prefer the other settings too. Anyone hear of suc like this?
    Problem Solver:
  • 15 Answers
SOUNDS LIKE A BAD CONTROL BOARD.
Posted on Oct 10, 2007
SOURCE:
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
Kenmore Elite washing mahcine HE3 quietpak2 Model#110.45862404 - The selecting cycle wash button does not follow command. It is only delicte and handwash cycle wash botton is working.
Sounds like a problem in the button panel, but could be firmware is in a knot, which is an easy fix: Try unplugging machine and plug back in 5 minutes later. Then see if it works.
Jun 19, 2015 | Kenmore HE2 Plus Front Load Washer
I have a 2 month old Speed Queen top load (542) after the spin cycle, the clothes are still very wet
i assume the majority of the water is being pumped from the machine? if the clothes are very wet check your "fabric Select" setting and ensure you are not wahing on delecate handwash or wool wash (knits) setting, in this setting there will be a very slow or no, spin so the clothes will not stretch and have to be laid out to dry this is normal. if you are on a Permpress or regular setting the spin should be faster, also check your cycle selection is for Regular or permpress and spin is not missed .
I hope this was useful
Feb 15, 2013 | Speed Queen AWS52NW Top Load Washer
Water left in machine (clothes dripping) after delicate cycle
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Dial won't turn to delicate or handwash...
Is it brand new?? if it is the factory did not align the knob (dial assy) properly with the main computer, and on top of that all the cycles you think you are selecting really isnt that cycle at all!! It is two back from full left or right whichever way is not fully extending. It is quite frustrating for me to get it back right when i replace the main computer! The first one or two took me a while to get it right again. PLEASE rate my solution as solved if you feel I answered your question accurately. Thank you
Oct 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
