Question about Home Security
139.53990ds not moving. Diagnostic LED blinking 5 times
I have a 3/4 HP 315 MHz Garage Door Opener (model# 139.53990DS). The opener will not operate via any remote or wall switch. The LED is lit on the wall switch and on the safety sensors. When the wall switch is pressed, you can hear a single click at the motor that sounds like an electrical switch, but the motor does not run at all. No sound comes from the motor. The Diagnostic LED blinks 5 times. I have reset the motor by unplugging and plugging it back in. It did not help.
  • 244 Answers
SOURCE: Craftsman Garage Opener Clicks only and LED blinking 5 times
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Posted on Feb 12, 2009
  • 8 Answers
SOURCE: Sears/Craftsman Garage Door won't budge
with the door down, disconnect with the emergency release, see if the motor operates
with no load...if the the track moves you probably have something obstructing the door
ie; a broken spring, door locks, etc ... the chain should be adjusted for just a little
**** mid way down the rail (1/4") if it still doesn't move ... call sears.
Posted on Mar 15, 2009
  • 3197 Answers
SOURCE: I have a 1995 Sear garage door opener that stopped working
The trolley (the part that moves back and forth and is connected to your door) of your opener is most likely jammed against the bolt just in front of the motor unit. You can remove the bolt or loosen the chain until your unit will run. Once the door is closed find the 'up limit' on the side of the motor unit and turn it about 3 turns in the opposite direction of the arrow printed on the cover. Now replace the bolt or tighten the chain. Whichever you first did.
Posted on May 28, 2009
  • 3197 Answers
SOURCE: Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Posted on Aug 26, 2009
  • 3197 Answers
SOURCE: I have a Sears Garage door opener
The code for 5 flashes is " Motor overheated or possible RPM sensor failure. Unplug to reset." Also if the door is stuck in the open position it could be the trolley is jammed against the bolt just in front of the motor unit.
Posted on Feb 07, 2010
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
I have a craftsman 3/4 hp 315 mhz garage door opener model 13953990ds when ativating it to open it only moves 6 to 8" forward and back and stop. i have tried all steps in the manual can get it solved
If you've readjusted the opener, and it still isn't working, you need to have a trained door technician come out and adjust the tension on your springs. To determine this, pull the red release handle to disengage the opener from the door, and try to lift your door by hand. You should be able to move the door easily, and it should stay at the half open point without falling or rising. If the door is hard to move, excessively heavy to lift off the ground, or will not stay open, the door itself is the culprit. If the door is fine, the opener will need to be serviced.
Sep 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
Craftsman 1/s HP 315 MHz garage door opener (Model 139-18470DM). The temperature here is currently 34 degrees celsius with the windchill. When trying to close the garage door from the main switch, the...
Check for some obstacle in the path of the light beam sensor that (should) be installed across the width of the door opening about 3-4 inches off the ground.
Jan 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
May 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
