Question about Clarion MAX675VD Car DVD Player
Reset personal code
When I connect the radio, the screen dislays "CODE INCORRECT" on top of the screen "ENTER PERSONAL CODE". Is there a way to reset this. I found on some other forums to press the "SUMMIT BUTTON", but I can't find it. Any help would be appreciated. Thank you.
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: I have a clarion max675vd
try to disconnect it from the power source..and connect it again and try to enter the correct code from the first time ..and see if it works ..It might be an issue with the fact that you inserted teh wrong code once too many ..
anyway disconnecting it will get it back to the start ..Lets hope will do ..cause freezing is not that usual..
in the moment it gets back ..try to reset it first ..try even before entering the code..it might work ..
Posted on Aug 26, 2010
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
Oct 15, 2012 | 1996 Volkswagen Golf
Radio won't work
When you disconnect your battery or remove the fuse and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacrurers service centre andget them to enter this code for you.
Jan 30, 2012 | 1987 Chevrolet S-10 Pickup
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
How to reset the raido
There is a trick to the procedure. You have to turn the key to position 1 or the first stop on the ignition. Turn on the radio and wait between 2.0 to 3.0 hours for the radio to reset and ask for the code. From the owners manual. My 97 takes between 2:25 and 2.5 hours to reset. Every radio is different.
To enter the code:
After installation or when the set has been disconnected from power, the set displays "codE" when it is switched on.
Enter the 4-digit code using the preset buttons. If the correct code is entered, "on" is displayed and the set is ready to use.
If you enter an incorrect code you must enter the correct code again from the beginning.
Incorrect code
If an incorrect code has been entered "rPt" is displayed. Enter the correct code.
After three unsuccessful coding attempts the set will lock and remain locked for two hours.
"OFF" is displayed.
During this waiting period:
the battery must be connected
the ignition key must be turned to position I
the unit must be turned on
Make sure the headlights are turned off to help prevent battery drain (please refer to page 2:6 for information on turning the headlights off). Enter the code again once this time has elapsed.
Ryan
Jun 11, 2009 | 1994 Volvo 960
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
How to retrieve current radio code for my 2004 chevy aveo?
Here's an easier way. Purchase a 9 volt battery powered radio / computer MEMORY RETAINER. Plug into your cigarette lighter/power socket SECURELY. AFTER replaceing the battery, remove 9 volt poer feed, and BINGO. Radio stations memory, clock will all RETAIN. their memory. Hope this helps
Apr 19, 2009 | 2006 Chevrolet Aveo
Chevy aveo issues
If you mean change the code needed to input into the radio then the only way it to take it apart and reprogram it. That would cost more then the radio itself.
So if you can't get the code in your either have the fix the button or get another radio.
Sorry
Apr 02, 2009 | 2006 Chevrolet Aveo
Clarion MAX675VD Car DVD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
