Question about Balboa Instruments Pool & Spa
Cfe and j82 error codes - Balboa Instruments Pool & Spa
    Top Expert:
  • Balboa Instr... Master
  • 8,673 Answers
Configuration error dip switches incorrect
Posted on Mar 24, 2018
Ariston fast 11 cfe leaking water
Leaks from the pressure relief valve usually can be addressed with replacement. Any other leak means it is time to replace the water heater.
Jan 07, 2015 | Water Water Heaters
Strong spa brand new tried to turn on first time error code came up cfe how can I fix this
sounds like air pocket try to force water into jets if you have an air pocket it will error out
May 11, 2014 | Pool & Spa
How to open service mode of kenstar colour television model KAF 21MSS-CFE
Ultra slime kenstar colour tv model s22010 open service mode
Dec 21, 2013 | Televison & Video
M#CFE 90000
What's the problem with your M#CFE 90000?
Aug 05, 2013 | Maytag Kitchen Ranges
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
Once you've got a serial console attached you can access the CFE which is a bit like the bios of the WGT634U. Start up minicom and apply power to the router while holding Control C. You should see something like the following:
CFE version 1.0.34 for BCM95365R (32bit,SP,LE)
Build Date: Tue Feb 24 03:21:41 CST 2004 (root@jackylinux)
Copyright (C) 2000,2001,2002 Broadcom Corporation.
Add MAC client version(DNI).
Initializing Arena.
Initializing Devices.
et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller
CPU type 0x29007: 200MHz
Total memory: 0x2000000 bytes (32MB)
Total memory used by CFE: 0x81BB1280 - 0x82000000 (4517248)
Initialized Data: 0x81BB1280 - 0x81BB3E90 (11280)
BSS Area: 0x81BB3E90 - 0x81BB45D0 (1856)
Local Heap: 0x81BB45D0 - 0x81FB45D0 (4194304)
Stack Area: 0x81FB45D0 - 0x81FB65D0 (8192)
Text (code) segment: 0x81FB65E0 - 0x81FFFFB0 (301520)
Boot area (physical): 0x01B70000 - 0x01BB0000
Relocation Factor: I:E23B65E0 - D:01BB0280
configure vlans
*********************** VLAN Driver initial ********************
Process LAN port(2-5) vlan Architecture...
SUCCESS: trying to create VLAN 0 for switch
SUCCESS: trying to add LAN port
Process WAN port(2-5) vlan Architecture...
SUCCESS: trying to add WAN port
SUCCESS: enable ports success
configure vlans...done
Automatic startup canceled via Ctrl-C
CFE>
Now you can get a listing of the available commands by typing "help". If you want to boot a kernel from a tftp server do the following:
CFE> ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;
CFE> boot -z -elf -tftp 192.168.1.10:vmlinux.gz
Or you can automate the process by setting STARTUP using:
CFE> setenv -p STARTUP "ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;boot -z -elf -tftp 192.168.1.10:vmlinux.gz;boot -elf flash0.os:"
The router will now try and retrieve a kernel image called vmlinux.gz using tftp from 192.168.1.10. If this fails it will go ahead and boot the kernel on the flash. The is quite handy as in conjuction with a NFS root, it means you can do all your development without modifing the original firmware.
Mar 14, 2011 | NetGear WGR614 Wireless Router
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Model CFE-175 serial # C8833960 Heater only clicks but will not light
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 23, 2011 | Sterling Heating & Cooling
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Mar 03, 2008 | Panasonic Workio DP-2500E Copier
Pool & Spa Logo
176 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Mike Raino
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
