Question about HP PhotoSmart 7760 InkJet Printer
Printer cartridge jam
PLEASE HELP! I am getting an error message on my printer that the printer cartridge us jammed. However, the cartridge is all the way over to the left and I can't get to it to try to unjam it. I have tried turning it off and on and I can hear it trying to move but it isn't moving. ANY SUGGESTIONS?????
  • Anonymous Jan 03, 2008
    I put a new color cartridge in my computer. It printed a couple of pages and then the cover that snaps shut popped up on the left hand side and I cannot get it to move? Is there a way to get in to be able to close the cover. It's an HP Photosmart 7760 InkJet.
  • wee tam Apr 18, 2008
    priny cartridge cradle is stuck. Nothing jammed in machine but attention light flickering so won't switch off and don't want to unplug.
    Sergeant:
  • 390 Answers
Oh dear, you may have a paper jam preventing it from movin, Open up the unit cover, get a torch and check thoroughly around it and rollers and down the back where paper goes behind unit too. I am willing to ber you find a tiny jam. Post back if it still won't print. Hint: sometimes you nedd to reset printer default settind and turn off and on again when jam is cleared to reset warnings.
Posted on Aug 31, 2007
SOURCE:
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Tip
My 2710 All In One keeps giving an error message that the printer cartridges are...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
C-4480 error message cartridge jams after
please make sure you no pieces of paper left inside the printer the restart it
Oct 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
My printer is giving me 2 error messages. One is
For the cartridge jam, that means that either the ink is not properly installed or there is one tiny piece of something blocking the sensors. Same is true with the carriage jam.Please try to look for small bits of paper and remove it.
Is the ink newly installed?
Aug 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
197 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
