Sony ss l100v
Watt
Need to order a bayonet tip for a model# ss-1000
Here is a complete used ss-1000 with bayonet tip included. https://www.ebay.com/itm/Scunci-Handheld-Prosteam-Steamer-1000-Watt-Wash-Steam-Cleaner-PS3888-SS1000/122787967149?epid=666008571&hash=item1c96bbb0ad:g:o74AAOSwVFlT5M6K
Nov 05, 2017 | Computers & Internet
Would a nakamichi soundspace 8 subwoofer work on a soundspace 9. I think the power is the same. Thanks Hugo
Nop, don't do that, the subwoofer power in the Nakamichi Soundspace 8 is 20 Watts and the subwoofer for Nakamichi Soundspace 9 is 70 Watts. If you put the 20 Watts Subwoofer on a 70 Watts input the subwoofer will receive severe damage. http://www.nakamichi.com/pdf/SS8_brochure.pdf
http://www.nakamichi.com/pdf/SS%209%20Brochure.pdf
Jan 29, 2016 | Nakamichi SoundSpace 9 CD Shelf System
Output wattage of sony speaker system model ss-cfx250
Passive speakers don't have an output wattage rating, that would be applied to the amplifier :-) The INPUT wattage rating of these speakers is 5 watts RMS per speaker.
Jul 14, 2014 | Sony Audio Players & Recorders
How do i bridge a 1000 watt amp to two 1200 watt subs
a sony 1000 watt rating is an exagerration. you will blow your 1200 watt speakers far before reaching sonys claim of 1000 watts
Jul 10, 2014 | Sony Xplod XM-1652Z Car Audio Amplifier
Just need help wiring up a transformer. 15PR200 SS
1) Copy following link for available resources for Kichler 15PR200 pro-series 200 watt transformer with selectable voltage output:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
2) Add comment and describe how many watts, and what gauge wire you are connecting to transformer.
Feb 09, 2013 | KICHLER TRANSFORMERS - PROFESSIONAL SERIES...
Need a woofer for sony ss-mf315
have you tried on amazon,ebay or you could go directly to sony's website and possibly order your 6.3 inch subwoofer
Dec 23, 2012 | Sony SS-MF315 Speaker
Sony Handycam DCR-SR200 e:91:01 means?
From page 32 of the user manual that is available for download here: (click here)
The error message that you are seeing requires that you to take the camera in for service, since a failure has occurred that the owner cannot fix themselves:
E:20:ss / E:31:ss / E:61:ss / E:62:ss / E:91:ss / E:94:ss
A malfunction that you cannot service has occurred. Contact your Sony dealer or local authorized Sony service facility. Inform them of the 5-digit code, which starts from E
Nov 26, 2011 | Sony Handycam DCR-SR200 Camcorder
Will i be able to swap the original speakers of the J520 with a pair of Sony SS-B1000, without causing damage to the new speakers? the Sony SS-B1000 has an Impedance of 8 ohms, and peak power of 120 watts.
Hi, As long as you like the way the speakers sound there is really no reason you cant use whatever speakers you want. To find out the approximate wattage of the stereo you are using look on the rear of the unit and you will find a tag that has " SPECIFICATIONS " on it. There you will see perhaps the a.m. and f.m. frequencies it's capable of receiving also there should be numbers saying something like" 100-240vac or 100-240v~ 50-60hz 1.2amp or 120watts.( if power is listed in amps only-1 amp's equivalent to about a hundred watts)Dividing the wattage by 3 will give you an approximate power out put. Example if your stereo draws 120 watts worth of 110 from the wall it will put out approximately 40 watts to each speaker. Changing from OEM speakers is all right as long as you don't try to hook up some 150 watt peak speaker to a stereo capable of just, say, 10 watts per channel. Doing this will eventually cause damage to the amplifier, not to mention causing about 30 percent total harmonic distortion-which take my word for you will know if you ever hear it! So long story short-use what you wish, just be careful not to overload the receiver-if the speakers are a bit to powerful for receiver you can lessen distortion by turning down the " BASS" as that takes the most power in a speaker. Thanks for choosing FixYa, I hope this helped-good luck, Prodzilla
Apr 15, 2011 | Audiophase J520 CD Shelf System
Can you tell me if a receiver Sony 7.1 works with speakers ss-mf515 and What happen because I use the higher volume and the speaker sound low?\r\nWhat kind of receiver works with the speakers I mencioned...
Since you don't name the receiver we have no idea of its audio power or compatibility with 'standard' 8-ohm speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-SS-MF515-Speakers-manual/id/956ci160/t/2/
Any normal standardized NOT-all-in-one-hi-fi-in-a-box amplifier will work with these speakers.
Apr 05, 2011 | Sony SS-MF515 Speaker
Connecting RCA plug to speaker wires
You can connect the RCA plugs to the speakers. But, as for using the red/white Audio outputs you may need an amplifier, those connections are used when going into a dvd or vcr that boosts the signal in their own environment. If you have a connection for headphones on the TV you might have better luck there for the speakers.
Jan 11, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
136 people viewed this question
 Grubhead
Grubhead
