Question about Mitsubishi VS-6043 60" Rear Projection Television
Picture and Color Diminishing
I just inherited a Mitsubishi 6043A and it has a couple of problems. Initially, the picture was OK but had vertical bars that appeared to move down the screen (not too distracting, but noticeable). Also, it sometimes powers up without picture. I can hear sound, but the screen stays black. Turning the TV off then back on usually fixes this problem. It happens when the DVD player is on before the TV. Today, the picture lost most color, and appears sepia. It seems like a loss of blue. Any idea on repair costs or ease for DIY?
  • havenoclue Jan 09, 2008
    We also recieved a VS-6043 4 years ago and the screen had colorful horizantal lines with normal sound, this morning the tv comes on sound only no picture HELP!!!
    Problem Solver:
  • 26 Answers
To be honest, your bulb probably went out if you're missing colors, or they are slowly burning out. I'd say check behind your screen while it's on. If that's the case, those are usually 100 bucks a piece. I've said this on many problems so far, but if that's not the case it's most likely the color "tubes" in the back out of wack. There's a way to adjust it from the remote but if you can't get it back to normal they may need replacement which is very expensive. I'd say if it comes to it, get it checked (usually 20-50$ for a house call estimate) and if it seems like to much, search around your local want ad for one with a broken screen or something and just use your parts in a different TV. ( is usually a good place to look)
Posted on May 29, 2008
Mitsubishi 62" DLP WD-62525 has no picture no menu only green vertical bars
can you see any of the on screen displays like menu or volume?
I've seen a problem with this model that only had white vertical bars and had to replace the light engine.
Mar 14, 2014 | Mitsubishi Televison & Video
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
No picture. Just a thin horizontal band of light running through the center of TV.
Your tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). You can easily find out the vertical ic on your tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
Mar 07, 2011 | Mitsubishi CK-35308 35" TV
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
52" RCA TV Plus color TV (12 years old)-picture is diminishing
Go into the menu and set contrast to full, bring brightness up to an appropriate level after.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
