Question about Kenmore Refrigerators
Refrigerator filter I' m trying to change the water filter, but the old filter doesn't have a release. Do I twist it or just pull it out? The model number is 795.71073.012.
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
SOURCE: I need to change the water filter on my refrigerator
Since I didn't have the service manual, I had to play around until I stumbled into a way to remove the filter. To remove the filter: 1. locate the filter (bottom front under the refrigerator door). 2. push the button next to the filter cap until the filter is released. 3 remove the fillter and take that filter to the local home supply store to make sure you have the correct match. 4. replace cap on new filter, remove inlet protecting caps on new filter, and push the filter into place.
Posted on Mar 20, 2009
  • 531 Answers
SOURCE: Whirlpool GS6NBEXRQ won't release water filter for change
press and pull
Posted on Mar 31, 2009
FreshWaterSy
  • 13 Answers
SOURCE: What is the part number for the water filter for a
The part number is 4392922 for the water filter. You can purchase this water filter at the below link for $ 34.49
http://www.freshwatersystems.com/p-3051-whirlpool-kitchenaid-deluxe-filter-4396510.aspx
FreshWaterSystems
1.877.335.3339
Posted on May 19, 2009
milten1
  • 1304 Answers
SOURCE: How do I change the water filter in the Whirlpool
the water filter is in the toe kick on the bottom
it is a push twist type and should almost pop out when in the right position.
the best buty online right now i know of is at appliancepartspro.com
your looking for part number AP3182816
29.00
tell them you want the dealer discount and order 3
you will use em and you might get an additional
15 percent off no guarentee
have a great day
Posted on Oct 06, 2009
How do I remove a refrigerator water filter bypass cap?
It should twist about a quarter-turn counterclockwise - like from the 3:00 position to the 12:00 position - then pull straight out. It fits the housing exactly the same way as the filter fits it.
Jul 25, 2014 | Fisher and Paykel Refrigerators
How to replace water filter
Twist then pull. It locks in place with a quarter turn.
Jun 20, 2014 | LG LFX25960ST Stainless Steel French Door...
How do i change the filter in the amana my ice taste bab do i need to cut the water supply off to change the filter
Water filter is located in the upper right hand corner of the fresh food side.
Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
Sep 14, 2011 | Amana ASD 2624 Side by Side Refrigerator
I can't remove the old filter to replace it. You're supposed to push the button in and it would pop out, but it won't go in. 56166501 is model.
If its been some time since you last changed the filter then you may need to pull the filter holder while holding the eject button. Don't twist the cap on the holder, just pull.
If you can't get a grip on it and the eject button still doesn't work then remove the base grille by openeing both doors and pushing the top and pulling the bottom to give you better access to the eject button and filter holder.
Jun 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The place where the water filter goes in won't open so I can't replace the water filter. It will not turn the 1/4 turn to the left as per the instructions. It seems stuck.
Hi there
These caps can be very stubborn to remove, the 'o' ring seal can almost lock it into place.
There are 2 things you can try
Switch off and unplug the fridge
Switch off the water supply and open the dispense valve
1. Use a hair drier to warm the cap, be careful as this can get very hot, you may choose to use gloves if it seems very hot, be careful not to overheat as this can distort the cap.Then twist anticlockwise and pull to remove the filter cap.
2. Put a shallow tray on the floor below the filter and cap, carefully and slowly pour hot (not boiling) water over the can then ,wearing gloves, twist anticlockwise then pull to remove the cap.
You may need to persevere if the filter has not been changed before.
Having changed the filter then plug in the unit and switch on the power and water and draw off water from the dispense valve in 5 second burst for about 2 mins to remove air from the filter and ensure that clean water is right through the fridge
Hope this helps
Gordon
Apr 22, 2011 | KitchenAid (KSRD22FKST) Side by Side...
We have a KitchenAid Superba Refrigerator trying to replace the water filter and the cap won't budge. model: KSRG25FKBT03/ turning counter clock wise. Do you have any suggestions?
Hi
Having changed the filter then plug in the unit and switch on the power and water and draw off water from the dispense valve in 5 second burst for about 2 mins to remove air from the filter and ensure that clean water is right through the fridge.
Good luck
Gordon
Apr 17, 2011 | KitchenAid Superba Architect KSCS25INSS...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Need to change the frig water filter
filter part number is fsp-4396710 @$39.95 it is located in the front grille on the left side. It unscrews and pulls out. You transfer the twist top onto the new filter and push and screw it back in.
Apr 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
