PGD30C0702E how do I clean this unit
Runs louder after cleaned condenser unit
The filthy condenser unit was also acting as a sound absorber. Now that the "absorbant" has been cleaned ..........................
Aug 05, 2015 | Refrigerators
Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Oct 03, 2014 | Heating & Cooling
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Clean unit
After making approximately 200 coffees, the internal brewing chamber and the
brewing unit must be cleaned (of coffee oils, etc.). The display will show
CLEAN UNIT alternating with the regular message. This indicates that it is time
to run the tablet cleaning cycle
Feb 20, 2012 | Jura Capresso C1500 Espresso & Coffee...
How do i clean a purge unit on mp610 canon? where is it located?
the purge unit is located where the print head rest itself.. normally it's under the right side of the printer.
You will need to remove the cover in order to clean the purge unit, you have to be very careful as the purge unit might have small spring and if it's not fitted correctly, it will damage the purge unit.
Easiest way to clean it is switch on the printer, and open the front or top cover...let the print head move to replacement position then pull the power out and clean the purge unit. It's a messy thing as it will be fill with ink. U can clean it using tissue and moist cloth... apart from that, don't think you can clean much of it unless you are able to open the whole printer up then you will have a better view and space to clean it.
May 25, 2010 | Canon MP610 Photo All-In-One Printer
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
Icing up of unit
When you clean the Ac unit, Make sure to take the Unit completly out and clean both the condensor coil as well as the Evaporator coil.
If you are able to run the unit with it out of the window. See if there are any service ports connected to the unit (Guage hook ups), or any OIL spots where is looks dark, (Checking to see) if its leaking.
Wasnt sure how you cleaned the unit, So just make sure both coils are cleaned well with water, and make sure to avoid getting to much water into the Electronics.
Good Luck!
Oct 25, 2009 | LG Heat cool Window Air Conditioner
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
