Autoload ipod shuffle - Audio Players & Recorders
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
My ipod wont shuffle anymore
How to Fix an iPod Shuffle That Won't Turn On
Things You'll Need:
* iPod Shuffle iPod USB cable Power adapter
The iPod Shuffle is the smallest member of Apple's line of MP3 players. During the device's lifetime, you may find that the iPod freezes or seems to not turn on anymore. Since the iPod Shuffle does not have a display attached to it, you cannot be notified of any device errors. However, there are several troubleshooting steps you can take to repair your iPod.
Instructions
Plug the iPod USB cable into the iPod Shuffle and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod Shuffle to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod Shuffle memory.
Connect the iPod Shuffle to your Mac or PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Hope it helped.
Have a nice day.
Feb 22, 2011 | Apple iPod touch
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    I Pod shuffle (2nd. generation) won't hold a charge
    Hold in the play button for 10 seconds to reset. If that fails:
    iPod shuffle Software Update and Restore
    Apple periodically updates iPod shuffle software to improve performance or add
    features. It is recommended that you update your iPod shuffle to use the latest
    software.
    You can choose either to update or to restore the iPod shuffle software.
    If you choose to update, the software is updated, but your settings and songs are not
    affected.
    If you choose to restore, all songs and data are erased from your iPod shuffle. All
    iPod shuffle settings are restored to their original state.
    To update or restore iPod shuffle with the latest software:
    1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
    has the latest software for all models of iPod.
    2 Double-click the software install file and follow the onscreen instructions to install the
    iPod shuffle Update.
    3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
    opens.
    If you’re using a Windows PC and the iPod Updater application doesn’t open
    automatically, you can find the updater by choosing Start > All Programs > iPod.
    4 Follow the onscreen instructions to update or restore iPod shuffle software.
    If you use the iPod Updater application and it doesn’t see that iPod shuffle is
    connected to your computer, turn iPod shuffle off and turn it on again.
    Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
    Ipod Shuffle 2nd Generation
    I can not remember where to put the button to listen to my ipod shuffle songs in order.I downloaded a song and have not heard it on my ipod yet.Thanks,Mary
    Nov 26, 2008 | Apple iPod shuffle Second Gen. Silver (1...
    IPod shuffle 1st gen. Not Recognized By PC
    Try a different USB port first. Here are some other suggestions:
    Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
    need to be recharged.
    â Make sure you have installed the latest iTunes software from
    www.apple.com/ipod/start.
    â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
    firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
    inserted only one way.
    â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
    turn it back on again.
    â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
    appear in iTunes or the Finder, the battery may be completely discharged. Let
    iPod shuffle charge for several minutes to see if it comes back to life.
    â Make sure you have the required computer and software. See “If you want to doublecheck
    the system requirements” on page 25.
    â Try restarting your computer.
    â If none of the previous suggestions solves the problem, you might need to restore
    iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
    â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
    repaired. You can arrange for service on the iPod shuffle Service & Support website at
    www.apple.com/support/ipodshuffle/service.
    Jun 09, 2008 | Apple iPod shuffle MP3 Player
    Cant get shuffle to work when not conected to pc
    How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
    Sep 15, 2007 | Apple iPod shuffle MP3 Player
    Green/orange flahing light on IPod and no music.
    From Apple.com Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
    Sep 11, 2007 | Apple iPod shuffle MP3 Player
    IPod nano and iPod shuffle
    The iPod nano and iPod shuffle are both small--3.5 inches tall, 1.6 inches wide, and 0.27 inches thick for the iPod nano and 3.3 inches tall, 0.98 inches wide, and 0.33 inches thick for the iPod shuffle. The iPod nano and iPod shuffle both use solid state Flash Memory--2.0 GB or 4.0 GB for the iPod nano and 512 MB or 1.0 GB for the iPod shuffle. However, the similarities end with the dimensions and type of internal storage, as the iPod nano is designed as a tiny but "full featured" MP3 player, with more in common with the iPod "Color" models, with a few notable exceptions, and the iPod shuffle, on the other hand, was designed as a simple low cost MP3 player that lacks a display and can only play music and transport files.
    Sep 29, 2005 | Apple iPod nano
    16 people viewed this question
     Grubhead
    Grubhead
