Question about Dryers
Frigidaire dryer leq2152eso
Not drying,
5 Suggested Answers
  • 266 Answers
SOURCE: MY DRYER Frigidaire Model Number
Sounds like your heating element has broken. Unplug from electricity. On the front of the dryer there are two clips that hold the top of the dryer to the front they can be tripped by inserting a flat blade screwdriver between the top and front panel apx 2 inches in from the side in the seam where the top and front come together. These clips are sprung steel and you have to push hard. (I usually give the screwdriver a sharp rap with a hammer) When you trip them you can lift the top up and backwards. Then about 12 inches down the inside front you will see a 5/16 nut that holds the front to the sides take them out. Then you can pull forward and lift the front off the machine. You will need to remove the belt you can look under the drum the belt goes thru two pullys one is a tensioner pop the belt off the tensioner and pay attention how the tensioner looks it may fall down and you will have to rehook it to put the belt back. I believe this model also has an access door at the tensioner and motor that gives closer access to the belt. Then you just lift the drum up and out of the dryer pull forward slightly before lifting up. The heating element will be exsposed in the back and the wire that was arching will be here. Remove the wires to the element and the mounting screws on the element pan. Unhook the Hi limit sensor on the pan and put it on the new one. Reinstall the element ect in reverse. The only problems you may run into is where the wires hook to the element can be hard to remove and unhooking the belt pay close attention to the tensioner and how the belt is attached to the tensioner and motor. This should only take you about 40 minutes to complete. I hope this helps
Posted on Aug 23, 2010
SOURCE: Frigidaire electric dryer model # LEQ2152ESO runs
probably a loose connection on the speed control board
Posted on Dec 31, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire front loading dryer model
Hi ckteaque....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
SOURCE: LEQ2152ESO FRIGIDAIRE DRYER trys to start but
what's the solution?
Posted on Oct 12, 2012
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
GOT A LEQ2152ESO it stoped drying how do i fix
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
May 01, 2014 | Frigidaire Dryers
Dryer make buzzing sound like a stuck relay when you push the start button. pushing dryness control gives flashing error signal. Model LEQ2152ESO
The dryer motors are common for lint build up in the motor at the motor switch. If you get the dryer apart again use a vacuum and small paint brush or compressed air and blow out the motor. Make sure you clean your external vent frequently and do not use flexible vinyl ducting.
Hope this helps and there is no need to replace the motor anytime soon.
Dec 22, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer model number LEQ2152ESO will get so hot after drying a couple of loads of clothes that you can't even get the clothes out of the dryer. It also makes a noise when it is getting hot. I have cleaned...
I would check the blower wheel. If it is loose or has any play replace it. Check the outside vent to see if air is blowing out the vent as strong as usual. If all that checks good the cycling thermostat is likely the problem. They are inexpensive and easy to replace. Here are a couple links that should help
http://appliancehelponline.com/dryerblowerassy.html
http://appliancehelponline.com/electricdryertroubleshoot.html
Oct 16, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My dryer Mode LEQ2152eso is getting very hot in about 15 minutes. Approx 120 degrees on the right top side. Hot enough that you cannot keep your hand on it.I have cleaned the lint filter and remove the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 23, 2010 | Frigidaire AEQ7000ES Dryer
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
