Technics SB-W33 subwoofer - Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
Tweeter not working
hi,
Remove the tweeter and check the same with one AAA cell. Connect the two leads between the leads of the tweeter. if ther is no crakking noice from the tweeter the its coil is burned. you have to replace the tweeter.
ok
Feb 07, 2011 | Technics SB-T200 Main / Stereo Speaker
Do I need minimum gauge wire for my speakers to work?
I wouldn't have thought so. The better the quality of the wire the better the sound you will get.
Nov 05, 2010 | Technics SB-T200 Main / Stereo Speaker
Looking for a replacement speaker for my Technics SB-LX7 floor standing 3-way speakers the top speaker on one of them is broken. Model # Technics EAS65PH313A6
OK. I suggest typing the model in on EBay and getting the cheapest one there is.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Technics SB-LX70K Speaker
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Speaker enclosures for SB-DV290
Yes technics is panasonic so call this number and tell them you are aking about the technics separates system. the number is for UK 08705 357357
Sep 30, 2008 | Technics SCEH790 CD Shelf System
TECHNICS SUBWOOFER SB-AS60
hi, i will sugest you , just clean the volume control with lighter fluid,, then let it dry,, its just a dirt,, try it,, ,, coz iv done it many times. . . . god bless .. gud luck
Mar 01, 2008 | Technics SB-AS60 Speaker
IC Component
Hi guardofsv....your Circuit may be ordered from any of the following Website URL's listed below....good luck my friend.
Aug 06, 2007 | Technics SB-AS500 Subwoofer
 Grubhead
Grubhead
