Question about Bosch GPL5 5Point SelfLeveling Alignment Laser
BOSCH GPL5 I have changed batteries in this laser and the beam is still very weak. Is there an adjustment foe this?
My bosch gpl5 has stopped working???
Make sure you put the batteries in right
Feb 06, 2014 | CRL Flexible Problem Solver Nozzles
Weak beam .can barely see espically when sun is shining.
How old are the batteries? The company appears to be proprietary and does not release much information.
Sep 02, 2013 | Topcon tpl4b pipe laser w/remote,red
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
Some DVDs play and some don''t. Why would that be?
Hello
It is due to weak laser beam from the laser unit. Laser Pickup Unit is one which sends laser beam to disc and recieves the reflected beam which contains the digital signal, and sends to the main circuit board for process. If laser pickup unit is faulty, the fault you designates here will occur. Replace the Laser Pickup Unit, with same type and number. OK.
Jun 10, 2011 | LG Televison & Video
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
My Onkyo DVD/CD Player CP704 plays CD's with no problem, but DVD's are a problem: I get "loading" but does not play and I get "no disc" on many occasions. What gives, any solutions? Thank you.
Laser Beam could be dirty, use disc cleaner or clean the eye beam on the laser pickup but the Laser ickup could also be bad, Mats has them
1-800-628-1118 First try Cleaning Eye Beam.
Jun 02, 2010 | Onkyo DV-SP404 DVD Player
Adjustment of laser guide
go to Makitatools.com and type in your model number and you can download a owners manual for this tool, on pages 8, 9 and also 21 it deals with adjusting the laser beam. Hope this helps and if I have answered your question would you please rate this response accordingly. Thank you
Dec 05, 2009 | Makita Saws
Problem sighting bushnell lazer boresighter
If you are attempting to use a red laser in daylight, you have to wear special glasses to see it well. You may have to complete this project with less light, such as after dark, or indoors. Only green lasers will show up in daylight. If this is not helpful, then I suggest that you change the batteries to brand new ones that you are sure of. There is probably no adjustment possible. Best wishes for your safe shooting!
Jan 04, 2009 | Bushnell Velocity Speed Gun
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
CD player will not play CDs
1.Check whether your cd s are good and readable
2.then the problem with the cd player laser beam reading assembly and its associating blocks
3. i guess your cd player laser beam lens is too weak or dead.
4. There is possible to change the lens system with a new one
5.Contact service centre for further rectification
Dec 19, 2007 | Audio Players & Recorders
Bosch GPL5 5Point SelfLeveling Alignment Laser Logo
Top Bosch Measuring Tools & Sensors Experts
Vuk B
JonSnell Electronic
JonSnell Electronic
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
