Question about Whirlpool Washing Machines
Whirlpool washing machine error code B5
My whirlpool washing machine pcb board indicating Error code has D5
  • 641 Answers
SOURCE: Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Posted on Aug 22, 2007
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Error code d5
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
the service manual which will tell you how to do some testing of the door lock, but in the end you may need both a control board and a door lock assembly. The good news, they are easy to change out, the bad news, they are expensive parts so you want to be as sure as possible before you buy and install.
Jul 02, 2015 | Maytag Washing Machines
WhirlPool PE Error
PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover.
Nov 10, 2012 | Whirlpool Washing Machines
Washer won't stay running error code DS
Oct 16, 2012 | Washing Machines
I am getting error code d5 on my duet sport. How do I fix this?
No d5 there is F05 Du> and DL The F05 is water not being heated . The D is for door switch not locking or unlocking .Must have complete model from washer to be sure
Oct 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 70 error on my whirlpool duet washer
Hi, F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board which needs to be replaced.
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport machine will stop mid-cycle and all lights will flash and d5 will show on display
The display is actually reading "Sd", which is a Suds detect error. This is an indication that you have either used too much detergent, are using the wrong type of detergent, or you have an obstruction somewhere in the drainage system. The following link explains the error code and how to correct it:
http://www.fixya.com/support/r3608687-sud_error
There is a follow-on link included that explains the steps necessary to check the drain pump reservoir. Read through the information provided and let me know if you have any questions. I hope this helps you.
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
