Question about Garden
Ryobi rbv26 where is spark plug located
Where is the spark plug located?
Cars have 4-8 spark plugs located on the engine block each is connected to the distributor cap with a cord.
Dec 10, 2016 | Cars & Trucks
Where is spark plug located on lincoln ls 3.0eng 2002
The spark plugs in the v6 can become an involved job as the upper intake manifold. The LS uses a Coil on Plug (COP) ignition system, meaning that the spark plugs are located under the ignition coil
Apr 04, 2014 | 2002 Lincoln LS
Where are the spark plugs
Locate the spark plug wires in the Cherokee cylinder head. In the 4.0 liter engine, the spark plugs are below the coil rail assembly. On the 4.7 liter engine, the spark plugs are located under each corresponding engine coil.
Read more: How to Replace Spark Plugs in a Jeep Grand Cherokee ' eHow.com http://www.ehow.com/how_4484626_replace-spark-plugs-jeep-grand.html#ixzz27zi6736d
Sep 30, 2012 | 2000 Jeep Grand Cherokee
Where is the spark plugs located for the 2002 4 cylinder highlander located. Plan on replacement.
First, remove the no. 1 engine cover. Locate the ignition coils, these will be squarish-looking packs with spark plug wires (4 of them) coming out. The wires should be going to the spark plugs, which are on the front and back side of the engine.
Grab the ignition coils or spark plug wires by the thick plastic piece at the end of the wire. Squeeze the end and turn it to release it from the spark plug. Pull back to remove the plug from the engine.
Slide the spark plug socket over the spark plug. The most common size of spark plug socket used on a Toyota Highlander is 16mm. Turn the socket to the left to unscrew and remove the spark plug from the cylinder well.
Mar 07, 2011 | 2002 Toyota Highlander
Location of spark plugs
The spark plugs are located in the front upper half of the motor (4 of them). Each spark plug has a spark plug wire connected to it. The spark plug wires run from the drivers side of the engine to the spark plug so just follow the wires to each of the spark plug locations.
Mar 06, 2010 | 1999 Chevrolet Cavalier
How to change spark plug where are they located at
Your spark plugs can be located in 2 different locations.
1 if your engine is sitting front to back of the vehicle your plugs will be located on the drivers side and the passengers side of the vehicle.
2 if your engine is set from one wheel well to the other than your spark plugs will be located on the front of the engine ( front towards the bumper/grill.) and next to the firewall.
4.6L, 5.4L & 6.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the coil on plugs as outlined under Ignition Coil in this section.
  3. Remove the spark plugs.
  4. Inspect the spark plugs
  5. Adjust the spark plug gap as necessary. Proper gap is 0.52–0.56 in. (1.32–1.42mm).
installation.
  1. Install the spark plugs and tighten them to 13 ft. lbs. (18 Nm) for 4.6L and 5.4L SOHC engines. For 5.4L DOHC and 6.8L engines, tighten the spark plugs to 15 ft. lbs. (20 Nm).
  2. Install the coil on plugs.
  3. Connect the negative battery cable.
Jan 09, 2010 | 2002 Ford Expedition
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
Spark plug location for Poulan 2300
Most likely to be found under the removable casing at the top of the chainsaw. The spark plug will have a black rubber spark plug boot which will identify its location. Remove the spark plug wire/boot to access the spark plug. The boot should just pull off. The spark plug will need the correct size socket to remove it.
Jun 14, 2009 | Poulan Garden
I can't find the spark plugs in my 2005 sonata
Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold.
please rate!
Mar 18, 2009 | 2006 Hyundai Sonata
Location of spark plugs in 2005 dodge dakota
To change the sparks on a 2005 4.7L Dodge Dakota you will need the following:
  • Spark plug socket
  • Ratchet
  • Torque wrench
  • Extension
  • Flat-tip screwdriver
  • Make sure the truck is cold!!!
Note you will have to remove the air intake located at the top of the engine, and will have to move some of the coolant lines out of the way.
At the top of the engine there are 4 sparks on each side. The coils are held in place with a 10mm bolt. Undo the 10mm bolt and unclip the coil. Next pull out the coil.
Insert the socket, with extension into the spark plug hole.
Remove spark plug.
Check the gap on new spark plug, it should match stock.
tighten to approximately 25ft.lbs. (check spark-plug packaging for exact torque requirements).
repeat this process with all other sparks.
be sure that no dirt gets into the spark plug holes.
Jun 24, 2008 | 2005 Dodge Dakota
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
