Question about Husqvarna Garden
Bracket clutch anti-rotation removed
My Husqvarna 48" Mower (YTH238) is two years old, and I decided to sharpen blades and do an overall clean-up (oil and all filters) while taking the deck off for cleaning and blade sharpening. For some reason (which I am clueless!), I removed the bracket clutch anti-rotation. When reassembling the deck to tractor, I did not replace this part before starting the mower (did not see it on garage floor). I started the mower, drove up my driveway and engaged the blades. They would not engage, and I could tell the mower was about to shut off. I immediately disengaged the blades and the mower kept running. I drove back down the driveway and attempted to engage the blades again. The same thing happened, and this time the mower shut down. When I attempted to restart the mower with blades disengaged...nothing. Engine would not turn over. I discovered the missing part and reinstalled it on the mower. I ttempted to start the mower and still nothing. Can I repair this? Or do I have to take to a Husqvarna dealer?
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 475 Answers
SOURCE: husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: When I engage the mower blades, the tractor tries to stall
Besides the reverse switch, the seat switch will also cause this.
Posted on Jul 12, 2009
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
  • 6468 Answers
SOURCE: my john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Posted on Aug 17, 2012
When beginning to move, the yth2348 mower clutch spins and cuts the green wires in two.
There should be an anti rotation bracket on the side of the chassis too stop the whole clutch from turning, only the bottom half of the clutch should spin. There are cut a ways in the clutch hub that the bracket sits into.
Aug 11, 2013 | Husqvarna Garden
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
I've got a 2005 husqvarna yth 2042 riding mower,i broke one of the belt guides,(on order)-the spring extension for the clutch,where does it hook to?
Not too sure which guide you are refering too, the only keeper at the clutch is the anti rotation bracket for the clutch itself, it bolts to the side of the chassis and the other end sits into a cut a way in the side of the clutch assembly.
Apr 24, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How do I get my lawn mower ready for spring time use?
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Feb 14, 2011 | Garden
I have a yardman 6.5 h,p.push mower. How do I drain the oil to change it and how do I remove the blade to sharpen it?
I am assuming you have a Briggs & Stratton motor. If you have a "yardman" engine the procedure is still the same.
Changing the oil: Your mower does not have a drain plug on the bottom of the mower. Remove the dipstick and tip the mower over on that side. Let the oil run out and leave it tipped over for 5 minutes or so to get all the old oil out. Replace it with 22 oz of good 10w30 or straight 30w oil. I personally use Mobil One and change it once a year.
Blade: With the mower turned over you will see a bolt in the center of the blade. Remove that bolt and the blade will come off. Use a box-end or socket so you don't mess up the nut. It may be hard to loosen at first. Inspect the blade. If it has not large nicks or the dings and the back of the blade is not worn too much (the curved part) you can sharpen it with a file or grinder. Try to take the same amount off of both ends of the blade. (If you want to know how to balance the blade let me know)
If the blade has large dings, is bent different on one side more than the other, or parts of it have cracks, replace it with a new one.
Don't forget to change the air filter.
Jan 04, 2011 | Garden
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ajusting mower deck on husqvarva lawntractor been trying to make it level,has two cutting blades and this mower is not very old bought it last summer,
I think the two bladed units are 42" and down in size. The 48" are 3 bladed units. There are instructions in the manual for leveling the cut. If you do not have a manual, look on line for a manual, google it. First step is to get the mower sitting on a level piece of concrete. That way you know which corner needs to be raised or lowered. Then make sure your blades are mounted correctly. Usually you can see the adjusters, threaded bolts and nuts, or pins. Usually the deck comes level and gets **** up by someone taking the deck off to swap or sharpen blades.
Mar 06, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Having a hard time to fill the bag and almost not cutting grass
Well it could be your blade on the mower, over the years i have had to profect my blade sharpening skills.
sometimes when a blade is shapened its not done correctly causeing a lack in the blade tossing the grass properly and more or less turning into mulch on the lawn.
You should have your blades on a push mower if used once a week through out the season sharpened once a season then
if you have large amounts of rocks, sticks and pinecombs then 2x a year
if you only use it here and there then ushally ever 2 years is good.
another issue could be the engine bogging down when going over heavy or wet grass. this is no fun..
what I do with my lawn mower is clean the bottom and spray it with PAM cooking spray has been far the best solution, spraying the bottom of the deck and blade.
Now saying that if you try this method then remember no wet grass so dont over water your lawn.
some people like to use POR 15 on the under side of their mowers as well but I havent tryed this yet but hear it works great.
so there is ways to prevent slow and no discharge into the grass catcher.
hope this helps but yes I would say clean the underside of your mower and have you blade sharpened by a professional. dosent cost much and so much more worth it.
Aug 14, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
