Question about Kenwood KAC-7252 Car Audio Amplifier
Power of amplifier
I have a qeustion will the kac 72-52 be power enough to push 2 12inch kenwoods 1200watts a piece bridged without cutting off
    Genius:
  • 1,139 Answers
If the KAC-7252 is to be bridged, the operation mode switch on the top of the amp is set to mono. When switched to Mono, the signal from the left channel input only is used. Bridging creates 4 times as much power so the KAC-7252 delivers 170 Watts per channel so that 340 watts total so that value 340 is multiplied by 4 and that gives you 1360 watts of power. so it will drive them.
Posted on Sep 10, 2007
  • Henry McKelvey
    Henry McKelvey Sep 10, 2007
    Remember to tell me if this works.
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
I need an appropriate speaker for my kenwood amplifier kac-5202
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Jun 12, 2011 | Kenwood KAC-5202 Car Amp
KAC-9104D Car Audio Amplifier: how to bridge...
Sorry this is a mono amp, you cannot bridge one channel
May 17, 2010 | Kenwood KAC-9104D Car Audio Amplifier
The subs aren't pushing out bass.
Hello crobins2,
The Kenwood KAC-6202 2-channel is only rated for 60 watts RMS per channel into a 4 ohm load. That just isn't much power for a pair of 12" subs. Even the bridged output is only 200 watts into 4 ohms, still at the low end for a sub, much less to share between a pair of subs.
Assuming that your subs are 4 ohm, you could probably get more sound by driving just one of them on the bridged terminals. But to get the best power with what you have, connect one sub to each channel, set the filter switch to the far right (LPF), set the operation switch to stereo (both channels driven), set the filter frequency (Hz) to 100 or lower, and adjust the input sensitivity as far clockwise as possible without causing distortion.
But, to do the subs justice, you really need at least 300-400 watts to share between them.
Hope this helps.
Sep 27, 2009 | Kenwood KAC-6202 Car Audio Amplifier
HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI KENWOOD KAC X1R??
Es un monoblock amplifier, esto significa que el amplificador es de un solo canal, y este tipo de amplificador no se puede conectar en bridge.
Aug 11, 2009 | Kenwood KAC-X1R Car Audio Amplifier
They are not wanting to play like they should
Hello again debrahood196,
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
May 17, 2009 | Kenwood Car Audio & Video
To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Help
If it only does it when bridged, the ohm load may be too low.
Is it blowing the fuse on the amp or the one near the battery?
Jun 15, 2008 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood KAC-7252 Car Audio Amplifier Logo
220 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
