Question about Saniflo Plumbing
My saniflo under the sink started beeping twice yesterday and continues every 6 minutes. What is that?
2 Suggested Answers
SOURCE: saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Posted on Jan 31, 2010
Acer aspire zs600 Has Black Screen and Beeps 6 times, then repeats beep...
You might want to start in the safe mode. Right after you reboot your computer keep pressing f8 and it should start in safe mode. Once there you could then possibly see if you can solve the problem.
Good luck,
Marty
Jul 15, 2014 | Acer Aspire ZS600-UR308 - Core i3 3220 3.3...
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
I have a Saniflo which manages waste from a lavatory, a shower, and a sink (all in same room). The saniflo is immediately behind the lavatory, the shower is about 2 m from the saniflow and the sink about...
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
Mar 02, 2011 | Saniflo Plumbing
Our saniflo system works ok, its just when left idle, the pump seams to start up every 40 secs. I've flushed it and held up the ball **** and it stills does it. Any ideas?
One thing to check is the check valve may be leaking back, float may be faulty, toilet maye be leaking and filling tank causing pump to come on.
Check out this link with a trouble shooting guide for this unit.
This first kink has information on different types of Santiflo systems.
http://www.saniflo.com/Downloads.aspx
This next link has a trouble shooting guide that covers these issues.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Jun 24, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo sanibest continually running , noisy ...
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
I have acer aspire 5572 NWXCi . yesterday show comment that computer hibernate but every i touch power button, the my notebook is not ON. the led batere just blink twice orange color. and the led power is...
This is just a start, report back with results and we can continue.
Unplug the battery and the power adapter for 30 minutes .. After this, plugin the power adapter and try starting up.
What happens? If there is no change, there is a cover in the bottom which you can open, two screws
Find the memory slot, this is just a random picture I got on my hands on, the memory may be under a diffrent slot
UNPLUG and REMOVE BATTERY
Note that we are only using the power adapter and no battery during this process, keep the battery removed untill you have closed the ram cover and the laptop is working again.
Gently snap the ram out of its sockets note the holders on the module sides. Take both out, turn the laptop over and try starting up again, Remember Always when removing components from a computer UNPLUG and REMOVE BATTERY
With no memory the laptop should Beep a few times, please count the beeps short and long for me, then reinsert the other ram module, make sure its well seated and theres noting on the table no screws or anything that would damage the computer, turn it over again, you can keep the cover open, thats why I said make sure theres no screws or anything under it. Try starting up, what happens? beeps? IT should start up. Note that we are only using the power adapter and no battery during this process
update me on the results.
Dec 08, 2008 | Acer Aspire 5050-3242 Notebook
Water leak from turboflush saniflo
water inlet pipe blows off when toilet is flushed
Nov 11, 2008 | Saniflo 013/005/007 Sanibest Toilet with...
Plumbing Logo
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
