Question about Thomson Televison & Video
Thomson tv 46rh44e free manual
I have misplaced my Projection Tv set as per above model's manual is there anywhere I can get one please, thanks estelle
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Posted on Sep 18, 2007
SOURCE: Free repair manual for projection tv
The listed manual is the one I purchased. I managed to get to the power supply. I was not being forceful enough to make the chassis move after I had removed the screws. The 4 each 1000µF and the 2 each 3300µf capacitors are bulging, just like everyone was saying.
Thank you for your response.
Posted on Nov 14, 2007
SOURCE: RCA Projection TV will not turn on
hey,
I just fix my RCA p46770ck with that faint click sound when you try to power on. It was the HV splitter for $74.and change. after a long hunt to find the source of the problem I did what my local appliance store said to do replace the hole board for $275 luckily I was able to return that because it did nothing different than my board/module click.... click.... clickclickclickclickclick turn on you peace of @#%! any way if you unscrew the back cover off you'll see a black box at the top left corner with 4 red wires going to it groped 3 and 1. The 1 is your HV (High Voltage) supply and then gets split to each tube. Oh you should of unplug the tv before you touch any thing HV is 30,000 volts after you unplug you should push the power button to get ride of all voltage. please feel free to contact me at Heicheltechservice@hotmail.com for any Q: I can get part numbers or help in any whey i can
Posted on Nov 27, 2007
okcfirewall
  • 80 Answers
SOURCE: Thomson Scenium 52''Rear Projection TV set -
you have a laser that has gone out blue or green take the face off and see which of the colors you need you can still find lasers on ebay if you need one but it will require someone with a little expertise to replace them. if this is not for you then its time for a new TV this is probably the best option its more expensive to fix in most cases than to replace..........I hope this helps
Posted on Jul 20, 2009
johnnydiode
  • 647 Answers
SOURCE: Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Posted on Oct 24, 2009
Testimonial: "Many thanks to johnnydiode and all the others on this site sharing their knowledge and providing a valuable service."
I FORGET MY INSTALLATION CODE FOR MY THOMSON TV/46RH44E
3879,3862,3886,3891,3853 are the codes to check. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 27, 2013 | Televison & Video
Tip
JVC HD-56ZR7J Manual Download
Download JVC HD-56ZR7J Projection TV Manual
Models: JVC HD-70ZR7J / JVC HD-56ZR7J
Have you misplaced your JVC HD-56ZR7J Projection TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC HD-56ZR7J Projection TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC HD-56ZR7J Projection TV manual.
I hope that helps.
_____________________________________________
on May 02, 2010 | Televison & Video
Tip
JVC HD-70ZR7J Manual Download
Download JVC HD-70ZR7J Projection TV Manual
Have you misplaced your JVC HD-70ZR7J Projection TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC HD-70ZR7J Projection TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC HD-70ZR7J Projection TV manual.
I hope that helps.
Thomson tv repair
Flashing red indicates internal shutdown due to fault protection.
Only a tech can diagnose the fault (and hopefully repair it).
Good luck with getting it done quickly. :)
Clive.
Oct 06, 2017 | Thomson Televison & Video
Thompson 46RH2LPS firstly by sound on the TV went off there I was using an external speakers for the sound for approx 04months, All of a sudden the power went off on my Projection TV set. the engineer...
Hi Mahesh Nagarajah,
I don't have the copy of the service manual on my collection on this model no., I've also checked my links online but this is currently not available. May you please double check the model no. and chassis no. of your unit.
May I know also if your unit is totally dead set (no indication of led light at the front panel), it will help diagnose where the fault came from.
Jdvillanueva
Sep 28, 2011 | Thomson Televison & Video
What the model lamp for projector thomson 50dsz644
www.myprojectorlamps.com/rptvprojector/THOMSON/50%20DSZ%20644.html - United States
www.chooselamps.co.uk/search/projector-lamps/make/THOMSON - www.soundandvisionav.co.uk/.../THOMSON-50DSZ644--DLP-TV-UHP-Lamp-.html -
There are some links above.
Mar 24, 2010 | Thomson 50DSZ644 50" DLP Rear Projection...
Thomson tv projection "52" light blinking.
It apears you have a low voltage problem. This is not an in home repair and may be time to consider purchase of new model. Hope this helps good luck
Jul 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Http://www.rcascenium.com/customersupport. RCA SCENIUM TV picture quit working
hi i have thomson rear projection tv model 44jw612s i have problem tunning passward i forget my passward so please help me soon i can not tunning the new channels i hope you will solve my problem thanks
Oct 24, 2008 | Televison & Video
Thomson tv
http://online.projectordoctor.com/Projector-TV-Lamps
http://beamerlampen.biz/projector-bulbs/projector-lamp-Thomson-44DLW617-Nr-5400.html
Dec 07, 2007 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
