Question about Haier AHD50 Dehumidifier
Haier HD N655E
Unit stopped working. Plugged in but will not work. Tried to remove control panel to access a fuse or whatever, but could not get it off.
  • 625 Answers
Try plugging it into a known live outlet. if this still doesn't work, you need to get inside it. find the enthalpy control - humidity control and see if it turns. a contact inside may stay open preventing the fan and compressor from turning on. check your on-off switch if there is one. to remove the case look in back for hex head screws or on the bottom of the unit
Posted on Aug 30, 2007
My Haier dehumidifier has the bucket full light on and won't reset. It's only a month old. I tried unplugging, resetting and i'ts still stuck on bucket full. Any ideas on how
sorry to say but the bucket level sensors on these tend to be a bit tricky , it seems theres two possible holes the piviot point for float can go in , only one is correct for sensor to hit right , but both allow float to swing , and there not marked either
Dec 08, 2014 | Haier Dehumidifiers
Never no water in dehumdidifer to empty
I'd suggest you (1) make sure dehumifier is plugged in, (2) the circuit it's connected to is live (breaker not tripped and fuse not blown - this is easily tested by plugging in an appliance (e.g., hair dryer) you know works). If the unit turns on, it is likely defective - unless there is a hose connected to the dehumidifier that reroutes the water removed from the air to a drain (is there moisture collecting somewhere within 6-10' of the unit?). If it doesn't turn on, and you've troubleshooted the above to ensure there is electricity to the receptacle, then it's either defective or the moisture setting for removal needs to be adjusted for the humidity in your basement. Perhaps it's dryer down there than you thought, or your hygrostat (? - whatever the doohickey is called that senses humidity level) is set at too high a level that it never turns on/trips in your area. Hope it helps.
Jul 31, 2012 | Haier 30 Pint Dehumidifier
Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
Hope this helps you solve the problem.
Apr 27, 2011 | Haier 45-Pint Dehumidifier
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Apr 15, 2011 | Haier Dehumidifiers
Unit does not turn on when the on-off button is pressed. No indicator lights come on. The line cord is good - I have 118 volts across the black and white wires inside the cabinet.
This unit has a 12 amp 125v glass tube fuse on the control board. Chances are you blew this fuse. This can happen if the unit is starved for air and ices up. you must take the front of this unit off to access the fuse of this control board.
Apr 08, 2010 | Haier HDN655E Dehumidifier
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I...
please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Sep 04, 2009 | Haier 45-Pint Dehumidifier
Haier HDN305 Dehumidifier
agaver
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks qrx1llb3 for the help!
After carefully removing the plastic covers (yes, u need to remove both, I removed first the back one then the front one by pulling up, then disconnect the cable that joins the panel on the front cover with the electronic board on the upper right area) I found the electronic board with the blown up fuse. My was under a blue plastic cover. I'll try to replace it and see what happens! thanks for the help! :)
Jun 27, 2008 | Haier HDN655E Dehumidifier
Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Aug 10, 2007 | Haier HDN655E Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Haier AHD50 Dehumidifier Logo
148 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
