Insignia ns lcd32
Yesterday, I turned on my TV to find red green and blue thin vertical lines on a black screen. It then progresses into blue and white lines that are thicker. The picture returned but the thick blue and white lines started up again after 15 minutes. Similar results today. The audio is fine. What is the cause? Thanks in advance.
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Check the connecting cable to display paned and its T'Con board [LVDS cable] for any loose contact with its either end sockets. Reseat it once and check. If you wish to get more details, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide option.
Posted on Jul 12, 2013
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
tvservice306
  • 458 Answers
SOURCE: red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Posted on Sep 04, 2009
SOURCE: insignia ns-lcd32 turns off then
your power sopply needs replasted
Posted on Apr 15, 2011
bugoy31
  • 1238 Answers
SOURCE: I have an Insignia lcd.
Good day!!!!
If your TV got a lines,no picture and sounds?
That problem is usually happen when the main board or system board is not initiallize..
There are 2 cause of that problem #1 is the power supply---if the power supply got voltage drop your main board is not initialize...Commonly cause of voltage drop is faulty capacitors..You have a better chances if the faulty capacitors is looks like leak/bulged on the top so that you can easily find it through visual check and you don,t need to use special meter could capacitance meter to trace the faulty capacitors...
#2 is the mainboard itself---if the main board is faulty or not initialize..usually the processor IC is bad andits not for D.I.Y it can repair only on the manufacturer...but the mainboard is available on the market that is the only way to end this issue if the main board is bad...
Posted on Sep 09, 2011
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
My screen has a thin, vertical, black stripe about one inch over from the right. It also has a tiny red vertical stripe next to the black one, as well a few blue ones.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 04, 2016 | Insignia Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
Sep 16, 2012 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
Insignia 32-lcd black screen and thin colored lines vertically
Most likly the signal connector is loose or dirty. (input) this would cause the red, gree, blue or a combination to not be connected.
Mar 22, 2008 | Insignia IS-LCDTV32 32 in. Television
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
