Question about Toys
Air hogs controller wont connect to hyperactive
Header car is charged controller wont connect
    New Friend:
I wouldnt worry about fixing it. ive had a few air hogs helicopters in my life, and they all broke within 3 days. my most recent one, i wasnt able to steer it. it would just go rouge and smash itself to peices by banging into things around it.
Posted on Jul 21, 2013
  • aidan lovick Jul 21, 2013
    but they only last for a week if your lucky. and my first air hogs item i got, when i was like 9, it wouldnt charge. and that started the day i got it. i would charge it for HOURS, but when i finally took it off the charger after like 3 hours, i would set it on a flat surface, i would try to make it take off, and it did (for about 5 seconds). again, case in point, air hogs SUCKS.
My Air Hog Black Ops helicopter blades do not spin. It is charged as lights on helicopter and controller work. I have tried setting controller to all 3 channels with no luck. Any ideas?
check over the helicopter first then hand controller
heli
could be the receiver chip or pick up on the helicopter
motor issue ?
didnt think it was direct drive .might be
have to chase a broken wire connection or other
if cogs or belts are used ..stripped or jammed or other
receiver
toast
Jun 18, 2016 | Air Hogs Havoc Heli Helicopters
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
Air hogs assault wont charge
The batteries are too old , or have not the mA of the toy need. Check out the both inconvenience.
Jun 20, 2013 | Toys
Air hogs charger blinks red then turns off
Make sure you have the switches set properly.
Dec 28, 2012 | Air Hogs Toys
Hyperactive air hogs rc car keeps going doesnt stop how do i fix it?
I had that problem to but I fixed it. I'm not sure if it would work because I don't have a airhogs hyper active I have a air hogs hyper active 5. So to fix it there should be a dial next to the tire on the remote so you have to put thatdial thing in the middle
Aug 17, 2012 | Toys
My air hogs hawk eye will run for about 2-4 seconds then shut down. Why is this happening?
my son has some Air Hogs helicopters and this happenes if it has not been charged long enough.You might want to replace batteries or check to see if you are charging it correctly sometimes they are hard to connect.Good luck
Mar 07, 2011 | Air Hogs Toys
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
My son's air hogs hawk eye will not charge. What am i doing wrong?
Make sure that the switch on the helicopter is on charge (CHGE).
Dec 25, 2010 | Spinmaster Air Hogs Red Defender Remote...
Air hog wall and ceiling rc car wont climb up walls anymore. New batteries did not fix it. 2 days old
I would check a few things:
1. Do you hav dust and debris on your tires/suction? make ure it's totally clean.
2. Are your walls completely smooth? itwont drive on uneven or rough surfaces
3. make sure that you are charging it correctly andthoroughly (refer to instructi sheets for proper method)
4. Mke sure you switch the mode from "ground" to "wall" on the front of the car.
Hope that helps! If not, contact Air Hogs Customer Care - airhogs.com
Nov 09, 2010 | Air Hogs Toys
Toys Logo
311 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
