Question about JVC LT-32E488 32 in. LCD Television
Update firmware video playback in usb device stop at 2:00 hours of reproduction aprox.
Lg smart TV, will not display files on hard drive connected by USB. It recognises the device tho?
Please specify what you mean when you say "windows format" and "Mac format". If you mean that it recognizes .WMV files and not .MP4, then that is simply because the codecs includes in the television are only current up to the manufacture date. The good thing about Smart TVs is that you can update the firmware and this usually includes codec updates. Check that first, should be in the menu somewhere, look for "update". The other possibility is that it is an M4P file or M4U or .MOV, which is an Apple video or audio file. These have been encrypted to ensure playback on Apple devices ONLY. Thanks corporate America!! You can find hacks online to decrypt and convert them but I would just download an .AVI or .MP4 version of whatever it is you are trying to play and test whether the tv picks it up or not. Then you'll know if it's your device (USB), your tv, or protectionist Apple (most likely)
Nov 22, 2014 | Computers & Internet
Zoom h1 handy recorder
Have you tried updating your Zoom's Firmware to the latest version? That may just clear and reset the device to normal operation.
Oct 06, 2017 | Music
Rx v373 firmware update
Usb crashes after playing several music and stops loading contents from usb. I had to turn the power off and on again to load. Is there any latest firmware for Rx v 373 yet?
Aug 16, 2013 | Yamaha RX-V373 5.1 Channel AV Receiver
Fix samsung kies firmware upgrade stopped working
UNPLUG ALL USB DEVICES.. UPDATING FIRMWARES DEMANDS SUFFICIENT AMOUNT OF POWER. THIS IS TRUE TO ALL MOBILE DEVICES. IT DEPENDS ON YOUR COMPUTER'S USB POWER SUPPLY. HOPE IT HELPS! THIS WORKED FOR ME.- JAMES_PHILIPPINES
Mar 20, 2012 | Samsung GT S3850 Corby II
Video is black and white
I have a pioneer dv-353 and had a similar problem.I fixed it by updating the firmware. just search internat for pioneer firmware update download the file and follow the how to.if u cant find it i can email it to u.
Apr 13, 2010 | Pioneer DV-310 DVD Player
I have a dell inspiron 1525 laptop and my cd/dvd drive has been corrupted and is missing and now i cant play movies or cds and it happened two months ago wat do i do
The CD, CD-RW, DVD, DVD-RW, Blu-Ray and any other drive that uses a laser to read data from a CD. In general, most optical drive problems can be resolved by:
  • Updating the optical drive firmware
  • Updating the burning software
  • Updating the DVD playback software
  • Updating the computer's video driver in cases of video playback issues
  • Updating the computer's audio driver in cases of audio playback issues
To download the Firmware of your machine click here. i have selected the default 1525 but if you click on enter the service tag, it will give you your computer's firmware. or you can check it in device manager as well.
you can also try deleting the upper and lower filters. in regedit.
in vista. click on start /type regedit in start search.
then continue the action and then click on the +HKEY_LOCAL_MACHINE / + SYSTEM / +CURRENT CONTROLSET / +CONTROL /+ CLASS /+ {4D36E965-E325-11CE-BFC1-08002BE10318} and on the right side look for upper filters or lower filters and delete them. and then restart the computer. it should fix this.
in case the issue is not resolved. you might need to get the optical drive replaced.
if this information was helpful. please rate the solution.
Sep 25, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
When i try to sync my SA3025/37 with the songs that i have downloaded from Napster to my win media player10 as soon as the sync process starts i get an error message (win has encountered unknown problem)...
Download & install the latest synching program.
Set your music files in the desired playback order by naming them in alphanumerical sequence such as 001_Drunken Monkey.mp3 followed by 002_Massachusetts.mp3 etc. prior to your transferring into the Digital Audio Player.
IMPORTANT: The player does not support the playback of copy protected (Digital Rights Management - DRM) music purchased from internet music stores.
You can download non copy protected music to the player via Windows Explorer
Hook up your player with the PC via the supplied USB cable.
Run Windows Explorer, and select the files to download from your music file source directory.
Drag and drop the selected files to the player, which is named as Philips in Windows Explorer.
Once the transfer process is complete, click on the removal icon on the task tray to stop and eject the player. When a message appears saying the USB device can now be safely removed from the system, click OK.
Unplug from the PC and enjoy the music on your player.
Upgrade the firmware
You can find the current Firmware version of your player in the settings menu under "Information".
Regularly check www.philips.com/support for new Firmware updates. If your firmware version is the same as the latest version posted on the support site then there is NO need to update the firmware.
However, if you do not have the latest version follows the steps below.
Connect the player to your PC.
Launch the Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA30XX -> Philips SA30XX Device Manager on your PC.
If you do not have this program installed yet, install it from the by-packed CD or download it from www.philips.com/support.
Make sure all other applications such as Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Make sure you are connected to the internet.
Click update, then follows on screen instruction to complete the firmware upgrade.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Audio Players & Recorders
PS3 HDMI problem
i also had the same problem with my Samsung 1080P.its seems there is a "handshake"issue between the ps3 and the tv.restarting the system helped solve my problem.also insert the cables once again.
Sep 24, 2007 | Sony Playstation 3 (PS3) Console
JVC LT-32E488 32 in. LCD Television Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
