Question about Retail Supplies
Cst berger 5 point laser. broke magnetic bracket/base. wher can i buy new base?
2 Suggested Answers
  • 48 Answers
SOURCE: which instruments does the the CST/berger DTEP diagonal eyepiece work with?
according to http://www.engineersupply.com The CST/berger DTEP diagonal eyepiece works with the following instruments:
  • CST/berger DGT-02 theodolite (56-DGT2)
  • CST/berger DGT-10 theodolite (56-DGT10)
  • David White DWT-10 theodolite (46-8890)
Posted on Apr 17, 2013
Lazermark won't self level
There are 2 leveling systems in the lasermark lasers. The original was belt driven. The belts are rubber O rings, and break down over time. take the bottom off the laser and you can replace broken belts. It's a simply yet elegant system.
The newer ones use leveling cams. A tear drop shaped wheel on a motor, that raises and lowers one end of an axis to tilt the laser. The problem is because they have a hook at one end, they put a magnet in the cam to tell the laser when to stop turning the cam. If however, it reaches the limit, and then gets bumped it'll get the leveling axis stuck in the hook of the cam, and because the magnet is there, it will never relevel. What you have to do is, disassemble the laser, unplug the leveling motors and pull the wires for the magnet sensor out of the stuck axis. then swap the sensor from the other sensor in (as it wont level without reading the sensor) and then turn the unit on. It should be able to level at that point. The put all the wires back where they go, and you're on your way.
Apr 20, 2014 | CST/Lasermark Self-Leveling Rotary Laser...
Which instruments does the the CST/berger DTEP diagonal eyepiece work with?
Apr 17, 2013 | Retail Supplies
I have a CST/berger Magna-Trak 202 magnetic locator that just stopped working.
Likely the on/off button is no longer at the right position to make contact with the tab. Take it apart, and you may need to glue a little piece of plastic to the button.
Feb 01, 2013 | Bosch CST Berger MagnaTrak 200 Series...
I need a manual. Power will not come on. Changed batteries. No power. Also, where does the red attachment that tells you to go up or down hook on? I have power to the unit which hooks to the pole.
Hi Richard.
The manual is available from this webpage.
http://www.cstberger.co.uk/uk/en/
Type lm30 into the text box which says "trade name/tool number" and click "start search"
Click on the thumbnail then to download the pdf.
Check for corrosion on the battery terminals and those in the laser.
From what I can see in the manual, there should be a clamp for the laser receiver that lets you clamp it to a staff.
The target plate (part 24 in the manual) has a reflective coating and there should be a magnetic holder for it.
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
My laser turns levels tries to spin but wont. I am told its the motor. can l buy a motor ?
Please contact CST/Berger directly for warranty service or parts inquiries about that laser.
Their website is here. If you click on the self-support knowledge base link and type in warranty service you'll be able to access a list of options for repair of your unit.
(If you have a product(s) that needs to be returned for service, please contact the Customer Support department at 800-435-1859 or click on the LIVEPERSON icon right now to obtain a RMA number before shipping the product(s) back.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 06, 2011 | CST/Lasermark Self-Leveling Rotary Laser...
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
Cant git my cst 24x to level up or stay level on 2 points
try making the base as secure to the ground as you can and the wing nuts on the legs firm to eliminate this from the problem. make the base as level as you can with a topedo level and secure the level to the tripod. put all leveling screws in the middle. all adjustments should be minor. go through your leveling sequence and if it wont stay level, you will have to send it off to be recalibrated
Dec 03, 2009 | Cst /Berger 24X Automatic Level
Retail Supplies Logo
83 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
