Question about Home Security
My K guard cameras stopped working after a lighting storm I need to now why.
After a wind storm this light stopped working. Saw some rust at the bottom of the sensor box. Replaced bulbs (just in case). What next?
Possibly a loose connection on one or more of the wires dangling from ththe junction box. Shut off power at service panel, remove fixture cover and check connections at wire nuts. If thre're OK, you either have broken connections in photo eye / motion sensor or defective sensor.
Mar 04, 2013 | Home Security
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Have a McIntosh MC602 used to drive two 4 ohm subwoofers. Worked perfectly until a close lightening strike took out several theater components. Even though it was turned off during the storm it was plugged...
it seems that the right channel is blown. the unit has no fuses inside, most likelly output transistors are gone. not easy fixable, you need to bring it to a repair shop. if you are in nj you may brong to ebcelectronics
Sep 12, 2011 | Mcintosh MC602 2-Channel Amplifier
I have an E1000 Linksys. It stopped working after the storm. I uninstalled the software, rebooted my computer and unplugged and waited for 2 minutes after nplugging the modem and router. No such luck. ...
Your Linksys most likely been zapped by the storm.
It pays to connect your computer equipment into a power surge protection power board to protect the equipment from storm and power surges.
Sep 01, 2011 | Linksys Wireless-G WRT54G Router
No picture on monitor but still plays tape green trigger light not working when remoter is used.
Try using normal operations and see if the camera is working fine. Else it seems like a faulty ccd. You need to exchange under warranty.
Cheers
TeaCii
If you own website, add live support almost free
Let real security guard watch your cam for $1/day
Jan 21, 2010 | Ktl Cctv CFB2056IR Black and White...
1991 Geo Storm won't crank over
sounds like the alternator went. try to charge the battery any autopart store offers it free. the with a volt meter check the volts at the battery with the car running it should be at least 13.5
Jun 11, 2009 | 1991 Geo Storm
Shutter guard won't close completely
buy another camera. Nikon sucks in my opinion. 2 years and the same issue.
Feb 01, 2008 | Nikon Coolpix P1 Digital Camera
Cheats splintercell.the game please.
Keypad codes Mission 1 - Police Station Keypad 1: 091772 Keypad 2: 5929 Mission 4 - CIA HQ Keypad 1: 7687 Keypad 2: 110598 Keypad 3: 2019 Keypad 4: 110700 Keypad 5: 0614 (if Dougherty gets through the door before you can) Mission 5 - Kalinatek Keypad 1: 97531 Keypad 2: 33575 Keypad 3: 1250 Mission 8 - Chinese Embassy, Part II Keypad 1: 1436 Keypad 2: 9753 Keypad 3: 1456 Keypad 4: 1834 Keypad 5: 7921 Mission 9 - Presidential Palace Keypad 1: 2126 Keypad 2: 70021 Keypad 3: 66768 Save ammunition If you find a room being patrolled by a guard or worker, wait until he leaves, then turn off the light switch. When he returns, he will immediately move to the light switch to turn it on. At this point, his back should be turned to you. Quietly sneak up and either grab or punch him without firing your weapon. Flares If you are pinned down by a turret, throw a flare across it. The turret will be distracted for a moment, which may be long enough for you to sneak behind it and disable it. Taking out two guards Shoot a sticky camera near the guard closest to you. When he approaches, use gas to knock him out. The other guard will approach to investigate. You must either shoot him with a non lethal round if you cannot have casualties, or take him out with a head shot if killing is sanctioned. This has to be done correctly or he will revive the guard that you knocked out. Eliminating guard threat without ammunition If you do not have ammunition and you find two guards, sneak up to one and take him hostage. Make sure that your hostage is facing the other guard or he will shoot you. If you do not have ammunition, hide in the shadows and wait for a guard to come up to you (or slowly creep up to him) then press R1 to punch him. Use two punches to knock out someone. If you need to knock out many guards without killing them, look around for a water puddle. Try to lure them into it, then shoot a Sticky Shocker into the water. This will knock many of them out. This works with any body of water, including the sewers in the Chinese Embassy level. Luring your enemy To do this, find a can or glass bottle to pick up. Once obtained, move to a location, preferably dark. While hidden, throw the can or bottle to an open area with an enemy nearby. When thrown, the enemy will wonder what happened and walk towards that location. After you have drawn him out, you can take him out for an easy kill. Hiding bodies After you have disposed of enemies in an area, make sure that you still hide them, even though no one is nearby. Before going to another checkpoint, the alarm may ring, and it will say that a body was found. Try to hide all bodies in hidden areas for best results. Quickly drop body When moving a body, equip your weapon. This will automatically drop the body. Hide face Have the diversionary camera equipped with the SC-10. Press L1 button before you zoom in and fire it at a wall. If Sam is close to the wall, he will put his hand in front of the camera to hide his face. You can try this with any sticky camera, but you need to be close to the wall you shoot it on for him to cover it. Rifle rapid-fire Equip the rifle and press L3. The bullets on the screen will be a bit darker. This indicates that you have switched to rapid-fire mode. Be careful, as you cannot simply hold the trigger as you could before; the gun will shoot as much until you release. Sniper mode: accuracy increase For better accuracy on sniper mode, hold L1. Note: This may take a few seconds to start. Escaping a room full of soldiers Take a sticky camera or smoke grenades and throw it near where the most guards are located. For the sticky camera, a control bar that tells you how to make a noise or use smoke will appear at the bottom of the screen. Throw the smoke grenade and the smoke should knock out some guards. When the smoke appears from the grenade(s), it is your chance to run for it. Knock out an enemy To knock out an enemy without killing him, equip the sticky camera and shoot it at his head. Aim slightly above the head to compensate for gravity. After he is down, pick up the sticky camera and use it again. You can also throw bottles to knock out guards. You must aim well and hit them in the head.
Aug 13, 2007 | Sony PlayStation 2 (PS2) Console
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
