Question about Little Giant Garden
Gfci keeps tripping - Little Giant Garden
  • 2,760 Answers
If a pump connected to a gfci brkr is tripping it , gfci has detected a connection from hot wire to ground !! this could be a high resistance connection still allowing pump to run but "leaking" power to ground thru restance connection , this pump could become dangerious (if short gets worse) and should not be used for this application
Posted on Jan 31, 2015
My 30amp 2 pole gfci circuit breaker keeps tripping right after i reset it. It's connected to my endless pool and has never trip before. Is it a bad gfci ?
Replace GFCI and see if the breaker is bad.
Otherwise, my guess is that you have a short in the pool or pool heating element.
If you have AFCI (arc fault), then a loose wire connection anywhere along the line will trip breaker
Troubleshoot resources:
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2015 | Electrical Supplies
Gfci keeps tripping
You need to determine if it is experiencing a ground failure or a short. You can purchase an outlet tester at Lowes for a low price that will indicate if you have an open ground, a short etc. If the GFCI outlet is bad then replace it.
Mar 18, 2014 | Coachmen 2009 Chaparral Mid Profile...
GFCI keeps tripping when pump is submerged
Install another GFCI
Do not use anything that trips GFCI in water.
Just get another one and be safe.
May 30, 2013 | Pool & Spa
LG dryer is shorting
A seriously dangerous problem! Call a repairman immediately!
Sep 04, 2012 | LG DLG3788W Gas Dryer
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
The gfci on cord keeps tripping
GFCI's trip because theire is current leaking to ground. This often can be be caused simply by electrical components getting wet.
Or, it can be caused by a serious short to ground.
Fist, check to see if the inside circuits are getting wet from an internal leak. If so, fix leak, dry off components with a har dryer, try again.
If GFCI trips, it should be serviced by an experienced appliance repair person.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Garden Logo
177 people viewed this question
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
