Question about Initial IDM-1731 Portable DVD Player with Screen
Disc is constantly "loading" but not playing - Initial IDM-1731 Portable DVD Player with Screen
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
Vbr220 will not play blue ray but will play dvd it ejects blue ray disks
Does not play disc
1.No disc. - Load a disc into the tray.
2.Disc has been loaded upside down. Place the disc with the label side up.
3.Disc region code does not match region code of the player.
4.Disc type is not the correct type to play.
5.Disc is damaged or dirty. Clean the disc or try another.
6.Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.2_9_2013_12_09_45_pm.jpg
Use the owner manual for additional information.
God bless you
Feb 09, 2013 | Vizio Televison & Video
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
A new "Tangled" movie disc not play in Blu-Ray
As newer bluray movies come out they are constantly tweeking the format. More then likely you need to update your bluray players firmware or software. There should be an option under the menu for the bluray player to update the unit of course this will require that you have it hooked into the internet via ethernet cable or wifi network.
Apr 11, 2011 | Vizio VBR231 Blu-Ray Player
Games hanging, screen dimming.
Uninstall the game.do a Scan disc and a defrag.Once done shut down restart and load game. let me know how it works. :)
Oct 21, 2017 | ASUS G71G-Q2 Notebook
For some reason lately my 360 has been picky about what games it will let me play and when it will let me play them. I keep getting a unrecognized disc error/disc its damaged or dirty clean with a soft...
try taking an air duster,you can get them in just about any office supply store , and sparing it into the disc tray's port, the laser eye may be dusty
Oct 15, 2009 | Microsoft Xbox 360 Console
Devil Summoner 2 Will Not Play
It's possible that you have a faulty disc. Check the disc for scratches or scuffs and use a disc cleaner on it or take it to a GameStop and have them clean it. I have a copy of Devil Summoner 2 for my original PS2 and it works fine. If all your other games work fine, then 9 times out of 10 it's a problem with the game.
May 15, 2009 | THQ Shin Megami Tensei Devil Summoner:...
Why does the disc drive never stop?
it sounds like the motor arm is dirty you will need to take it a dialer or if you can do it your self you will big job on so good luck
Jan 02, 2008 | Microsoft Xbox 360 Console
7" dvd player
Yes, the lasers are notoriously crappy on many of those portable DVD units. Try a Sony model, I've found them to be considerably better built.
Sep 12, 2007 | Televison & Video
Initial IDM-1731 Portable DVD Player with Screen Logo
35 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
