000300017 - Magenta Ink Cartridge Error
When I turn on the printer this shows me error " Serv Tec 000300017" I changed the magenta toner but the problem continues.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
I think you need to take the printer to service center as it may be requiring some kind of service.
Posted on Jul 12, 2013
Basti
  • 1447 Answers
SOURCE: Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Posted on Sep 02, 2008
SOURCE: Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
POCBM
  • 121 Answers
SOURCE: hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Posted on Apr 02, 2009
  • 7 Answers
SOURCE: Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
SOURCE: Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Posted on Aug 17, 2009
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Cartridge Error - Interference with magenta communication
check under the ink cartridge there is a seal it is probably missing look at the other ones you'll see the seal but on that one it will be missing
Oct 23, 2012 | Lexmark Interact S605 All-in-One Color...
Error 9-355 on dc12 xerox
That is a magenta toner empty message, either the magenta cartridge is empty or there is an issue with the magenta toner dispensing.
Nov 14, 2009 | Xerox DocuColor 12 Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
I have a xerox phaser 8500. At startup it states
The magenta toner (powder) in the cartridge is "piled up" to one side.
1. Remove the magenta cartridge.
2. Holding the cartridge ends with your hands, "rock" it side to side a few times, then "roll" it forward/backwards a few times.
3. Put back in printer.... it should work ok.
4. If not, then power OFF the printer and unplug the power cord from the wall or power strip.
5. Turn ON the printer with the power cord disconnected.
6. Plug power cord back in and turn on printer.
7. It should work ok now.
Hope this helps!
Sep 08, 2009 | Xerox Phaser 8500/DN Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
19 people viewed this question
k24674
