Question about Marantz SR-48 Mark II Receiver
48 manual marantz sr
I have a marantz 48 sr and am unable to tune the radio to an accurate AM setting, the unity seems to only lock on to signals at 10's level. How can I overcome this issue?
5 Suggested Answers
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
SOURCE: Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Posted on May 15, 2009
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
SOURCE: My Marantz SR-5000 will not power up. All
Doug
Did you ever get this problem resolved? I have a chance to buy one of these from a guy who indicates he's having the same problem, but if fixing is going to be a bit expense, I will pass.
Posted on Dec 08, 2010
Marantz st-48 wont pick up fm signal
If you are inclined to try to service this unit the first step is to download a service manual, this is a sight that has a copy of the manual for download for a price
http://www.marantz.owner-manuals.com/ST48-service-manual-MARANTZ.html
you will require some hand tools, soldering iron and desoldering brade and some solder, multi meter and some type of signal tracing device like and oscilloscope or and audio tracing amplifier.
Look for missing power supply's to your RF front-end circuits and FM discriminator , also track down the analog switching ic to varrifie that this unit is functioning and selecting the FM circuits
if you still kneed help contact me further with your findings and a copy of the service guide
Have a good day and good luck
Best regards Falco
Nov 04, 2013 | Marantz SR-48 Mark II Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Marantz sr 5001 turns on but no sound
Answer lies on page 48 of your
Marantz SR 5001 Manual
If problem is not resolved, it may needs servicing.
Aug 23, 2012 | Marantz SR5001
Marantz SR-14 EX 5.1 Channels Receiver fuses.
Changing the type of fuses in your receiver will not change your sound quality at all.
Jun 07, 2012 | Audio Players & Recorders
Marantz sr 4000 powers up, but no sound
Try plugging in headphones, if they work, it sounds like outputs have blown,
Mar 18, 2012 | Marantz Audio Players & Recorders
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
Jan 10, 2009 | Marantz SR-18EX Receiver
Marantz SR 7200 Receiver
DSP (Digital Signal Processing) Board is probably defective or has Poor solder Connection on one of the Ic's on that board. Board cannot be Obtained from Marantz. Must be troubleshot at component Level and requires a very knowledgable tech to repair it. I have done a few of these in the past and usually charge $50 to Evaluate and Give estimate. kstahl65@att.net
Dec 26, 2007 | Marantz SR-7200 Receiver
Marantz SR-48 Mark II Receiver Logo
44 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
