Question about Dishwashers
Delonghi dw28w dishwasher
Unable to open door with or without power on. How do I get door open
How do I open door of the new 18 Danby dishwasher. This model has no latch under handle.
I assume you have gone through instructions supplied fully. You will have to contact, Danby directly, there should be contact information in the instructions.
Mar 11, 2017 | Danby Dishwashers
Dishwasher door will not close dishwasher come on with door open.
Good Morning Garthraie, thanks for your post!
I see that the door on your Frigidaire dishwasher appears to be locked and will not close. Could you please advise if the control panel has any lights lit up on it? Also, may I have the model number of your dishwasher? You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. With this additional information I would be able to assist you further. -Matt
Apr 12, 2016 | Frigidaire Dishwashers
How to remove dishwasher
  1. Unplug the dishwasher, usually under the sink.
  2. Turn off the supply faucet to the dishwasher, also under the sink.
  3. Disconnect the dishwasher supply hoses and the drain hose which usually empties into the garbage disposal. Have a small bucket or pan and some towels ready, the water in the hoses will leak out.
  4. Open the dishwasher door. There should be 3 or more screws holding the dishwasher to the cabinet. Remove these screws and re-close the dishwasher door.
  5. Grab the dishwasher door handle and gently pull the dishwasher outwards, lifting slightly and moving side-to-side as space allows.
  6. If it is unable to move due to the trim plate at the front of the base of the dishwasher, remove that too. Otherwise, just leave the trim in place.
  7. Gradually continue to pull the dishwasher outwards, and push/pull the hoses and power cord out along with it.
Apr 04, 2014 | Kenmore 24 in. 17032 Built-in Dishwasher
Unable to open the door
-Make sure your power source has juice.
Good luck
mai
Dec 20, 2013 | Dishwashers
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
We came home from holidays a few years ago and the dishwasher (Westinghouse 905) just didn't turn on. We've tried it repeatedly since then and are unable to get it to turn on. The power point works for...
Appliances that sit without use, usually have more problems than just the original problem.
In your case I would first check the power conection on the dishwasher. located under the machine
If this is fine then I would move on to the door switch.
these are comon problems that could be inexpensive fixes.
Jan 12, 2010 | Dishwashers
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
My Delonghi Magnifica 3400 has a problme with the front access door popping open when power up, brewing and powering down. Are there any suggested fixes for this issue? Also, is there anyway to make the...
My Delonghi Magnifica door was popping open too when the machine would cycle on or off. I found that the shoot on the inside of the door was stuck. This chute is spring loaded. The chute guides the coffee from the diffuser to the dispenser ports. I think it must have been coffee build up on the back side of the chute making it stick. So when the diffuser passed by during cycling the chute would not move out of the way. This makes the door pop open. I cleaned the chute so that it moves freely and no more trouble.
Apr 05, 2009 | DeLonghi EAM3400 Espresso Machine
How to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Jan 03, 2009 | Dishwashers
Dishwasher not washing dishes properly
Thanks akubra_lands, it worked for me too on model DW28W. I thought I should elaborate on your answer for anyone else who comes across this while researching the same problem.
The repair is ridiculously simple (takes about 10min) and the only tools needed are 1 philips/posidrive screwdriver and 1 flat blade screwdriver. Assuming you've unplugged it from mains power:
  1. Tip the dishwasher on its right hand side (looking from the front).
  2. Remove 4 screws from the metal base - 2 front and 2 rear (the rear ones have anti-rattle washers on them).
  3. Pull the base away, taking care of the pair of wires leading to the flood indicator float switch which is still attached to the base.
  4. Remove all 4 screws which fasten the solenoid valve to the pipe which leads from the pump upwards to the center of the tank (which feeds the lower spray arm).
  5. Pull the solenoid/valve body off the pipe and you will see it has a whitish plastic flap with a hinge at the top end.
  6. Use the flat blade screwdriver to gently prize open one side of the flap hinge and twist the flap until it is completely free of the valve body. Put the flap to one side.
  7. Replace the valve body, without the flap, and secure all 4 screws.
  8. Reassemble the dishwasher. Done
Now take a moment to admire the handiwork of the engineer who planned the failure of that innocent little plastic flap around 6 months after the expiry of the warranty.
I actually had a repair man come and look at the problem, and yep, right on cue, he told me it needed a new pump motor. $300. When he realised I was on to him he just gave up. So hard for repair people to do an honest day's work these days..
Nov 24, 2008 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
