Question about Ryobi Tek4 Professional 4-Volt Infrared Thermometer RP4030
How do i get my ryobi rp4030
Wont turn back on after recharging the battery
2 Suggested Answers
  • 183 Answers
SOURCE: Do Ryobi rechargable batteries fit other brand rechargers?
they dont fit at all
Posted on Jul 29, 2010
Ryobi blower flashing green red when charging Won't charge
I have run RYOBI printing presses for the last 30 years and I bought a RYOBI rechargeable drill and rechargeable garden tool. I am disgusted by how cheap they were and how the batteries just gave up. I have heard about bumping a battery by running a good battery thru it. It was suppose recondition the battery, however I got two ruined battery for that.
Jan 04, 2018 | Ryobi Drills
Is there a method to bring power tool batteries back to life?
Yes! Rechargeable batteries can be rejuvenated by draining them fully and then recharging fully and then repeating a few times! The trick is to fully drain and fully charge!
Jan 21, 2015 | Ryobi Drills
How to fix a Ryobi cs120l saw? shaft rotates only part of turn with each trigger pull
It sounds like your battery is shot. I would get a new one, charge it and you should be fine.
Jan 04, 2015 | Ryobi Drills
How to calibrate Ryobi digital thermometer?
Wrong. You need black body to check accuracy of IR thermometers (unlikely that you will have one). Accuracy bellow 50F is +/-3F and other ranges is +/- 1.5% of the reading.
Read the manual: http://www.ryobitools.com/product_manual/file_url/478/RP4030_656_trilingual.pdf
Jan 04, 2013 | Ryobi Tek4 Professional 4-Volt Infrared...
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Lithium batteries?
Just got a reply from Ryobi tech service and it says that "all Ryobi 18V platform power tools can accept and use the lithium batterys, but you must use the charger for the lithium to recharge them. Hope this helps. Dave
Feb 11, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Nov 25, 2008 | Hand Tools
Ryobi Tek4 Professional 4-Volt Infrared Thermometer RP4030 Logo
32 people viewed this question
Top Ryobi Measuring Tools & Sensors Experts
JOHN LAPIER
Vuk B
ray gallant
Are you a Ryobi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
