Question about MagnaFlow 2004 Lincoln LS - 3.9L V8, with LEV emissions, with California emissions system - Catalytic Converters
Engine turns over but will not start. what would be the trouble?
Cranks over fast but just will not start. don't know where to start replacing parts. It has a 160k miles
Have you checked to see if it is getting gas to the engine? If you have someone turn the key forward without starting the car while you kneel next to the wheel well by the gas cap you should be able to hear the fuel pump make a "humming" noise when the key is turned forward.... If fuel pump is working correctly I would replace fuel filter (cheap part usually around $15) also check and make sure your getting spark to the plugs
Posted on Jul 12, 2013
Craftsman Intek Plus 18 HP engine won't crank
Adjust the valves. I had the same problem.
Jun 15, 2013 | Craftsman Garden
Hyundai Iload diesel won't start, have replaced engine in van with changeover from wrecker & it turns over but doesn't fire up
run the scanner to reset the ECM and immobiliser
make sure that the cranking speed is fast
check for air in the system
check that the stop solenoid is connected
Nov 03, 2012 | Hyundai Cars & Trucks
Volvo 2005 EC210 BLC Engine Crank but no start .display shows code 140SID and 250 9
It can be faulty fuel pump or clogged fuel filter or its issue with starter or battery or may be problem with sensors.There are few possibilities that can cause these problem,there are few help links provided related to these issue. Click the link below and refer the troubleshooting procedure to solve the problem:-----
Engine cranks but will not start? http://technoanswers.blogspot.in/2012/02/engine-cranks-but-will-not-start.html
-------- Landcruiser prado won't start http://technoanswers.blogspot.com/2012/10/landcruiser-prado-wont-start.html ------- 2007 ford expedition engine cranks but wont start http://technoanswers.blogspot.com/2012/10/2007-ford-expedition-engine-cranks-but.html
: Engine Cranking Fast but not Firing up? http://whatisbyme.blogspot.in/2012/05/1999-lexus-gs300-engine-cranking-fast.html
1997 Oldsmobile Cutlass Ciera: The Engine cranks but not start? http://schematicsdiagram.blogspot.in/2012/04/1997-oldsmobile-cutlass-ciera-engine.html
Mazda MPV cranks but will not start? http://technoanswers.blogspot.com/2012/01/mazda-mpv-cranks-but-will-not-start.html
-------- MAZDA MPV WILL CRANK BUT NOT TURN OVER TO START? http://technoanswers.blogspot.com/2012/01/mazda-mpv-will-crank-but-not-turn-over.html
--------- Vehicle Cranks Fast but Won't Start http://whoisbyme.blogspot.in/2012/07/vehicle-cranks-fast-but-wont-start.html
How to test Crankshaft Position Sensor? http://fordrepairhelp.blogspot.in/2012/03/how-to-test-ford-focus-crankshaft.html
These details will help,keep updated for more help.
Oct 16, 2012 | Cars & Trucks
Frontier with yd25 engine cranks but will not start
are the plugs actually working properly though. you can test by removeing the glowplug rail & test each plug individualy with an ohm meter one probe where rail goes the other where the socket goes on to undo them. I don't know what the spec is but they should all be about the same. the other way is to remove all glow plugs & power them up & see if they glow red after a few seconds they should all take about the same time to glow red. Careful as they get red hot real quick so don't touch them
Oct 05, 2012 | 2008 Nissan Frontier
I hit a deer while on the highway, we only have liability, no comprehensive coverage, and it messed up my drivers side headlight & turn signal & a piece of the grill. My husband fixed the...
Hello! I don't see a connection between the headlight issue and not starting...However I definitely see a connection with the accident and not starting...When you say "not starting" do you mean the starter doesn't crank the engine or it does crank the engine but won't start? Do you have a meter and a wee bit of experience using one? If you do we can isolate this fault together...Send a comment...Guru...Saailer
Sep 21, 2011 | 2000 Pontiac Montana
When my solenoid fried, I replaced the starter on my 02 FLHRSEI with an aftermarket starter. I have 103,000 miles on the bike and lately it starts hard. I have never changed the fuel filter canister...
If the starter is turning your engine over fast enough, it's not the starter. If it's struggling to turn the engine over, it may indeed be the starter. With over a 100 thousand miles on the bike, I'd suspect the fuel filter would need to be changed. One other cause could be low compression. An engine with low compression requires the starter to turn the engine over longer and faster to get the engine to fire off. I call this "spinning the engine up" like a jet engine has to do. The RPM will increase as the starter spins it and eventually it'll fire. This would mean that it's time for a top end job including rings and a valve job. But, it could be something to do with the fuel injection system. I don't know anything about fuel injection. Sorry. But, I do know that it's supposed to sense the temperature of the engine somehow and enrichen the mixture when the engine is cold.
Good Luck
Steve
Aug 22, 2011 | 2002 Harley Davidson FLHR - FLHRCI Road...
Why want my truck start. Turning. Over fast
When you say it is "turning over fast," I'm assuming that the starter is engaging and actually cranking the engine. Not knowing the YEAR and MODEL of your truck, I can't even guess which engine it has.
Whether it has a timing CHAIN or a timing BELT in the engine, chances are that is broken and that replacing the belt or chain will likely solve the issue. Hope that's helpful!.
Jul 01, 2011 | Lincoln Navigator Cars & Trucks
For the past 2 weeks, when I try to start my 2003 Nissan Xterra, it seems sluggish, but the engine will turn over. On 2 separate occasions, when attempting to start the engine, it wouldn't turn over ...
Checked Cables how?
Looking & Touching isn't doing anything
You have to do a voltage drop test or remove
& clean the ends. I would do both
Remove the starter & have it tested at parts store,
assuming you don't know how to do a voltage or
current test while cranking.
May 24, 2011 | 2003 Nissan Xterra
My 2005 stratus wont start turns over but doesnt start the trouble code is p0340 so i changed cam sensor and crank sensor still wnt start i need help so bad
2.4 L?REMOVE CAM SENSOR..CRANK ENGINE..MAKE SURE CAM IS TURNING..IF NOT..TIMING BELT IS BROKEN OR STRIPPED..NEW BELT SHOULD FIX PROBLEM..MAKE SURE YOU CHECK/REPLACE WATER PUMP/IDLER/TENSIONER
2.7L?REMOVE OIL FILL CAP AND SEE IF CHAIN IS MOVING..IF NOT..YOU HAVE COLLAPSED TENSIONER..YOU WILL HAVE SOME VALVE DAMAGE..LET ME KNOW IF TOU NEED MORE INFO
Dec 30, 2009 | 2005 Dodge Stratus
1995 ford explorer doesn't start, crank & cam sensors replaced
Does you fuel pump delivers fuel. Is it there a spark.
Dec 29, 2009 | 1995 Ford Explorer
MagnaFlow 2004 Lincoln LS - 3.9L V8, with LEV emissions, with California emissions system - Catalytic Converters Logo
218 people viewed this question
Top MagnaFlow Electronics - Others Experts
Lawrence Oravetz
Vernon Taylor
Are you a MagnaFlow Electronics - Other Expert? Answer questions, earn points and help others
