Question about Ryobi Tek4 Professional 4-Volt Infrared Thermometer RP4030
I recharged the battery and now can't get it to turn back on. Help
    Master:
  • 678 Answers
Read maintenance section in manual:
http://www.homedepot.com/catalog/pdfimages/11/11fdc767-6de2-44f1-8077-f4e574ca9f0d.pdf
Measure Voltage on the battery to see if battery is the problem.
Posted on Aug 14, 2013
Have a 1996 nissan terrano v6 petrol. The battery went flat and I recharged it. When I put the recharged battery back in the car sounds an alarm and wont start (immobiliser?). The alarm stays on for a...
When the alarm sounds, turn the key to the RUN (NOT START) position, then OFF - do this 10 times rapidly.
Many alarms will turn off and allow the car to start with this method.
Nov 17, 2013 | Nissan Cars & Trucks
HOW TO RECHARGE THE INBUILT BATTERY FOR THIS PRODUCT?
It is hard to help find a solution for you without more specific info on this. It says you have purchased this(what?) product in the 60w version and it(what?) came with no manual. I would help you figure out how to connect the battery charger(what type?) to the back(of what?) or to the wall socket. Do you turn on or off the switch on the back(of what?) while charging. AND you WOULD APPRECIATE a CORRECT answer. Please< I need you to help me understand what you are asking before I can help you. I am here to help. If it uses a backup battery like a pc, you don't charge it. If it(whatever it is) uses a battery for power, you probably plug it into the wall overnight without turning it on to charge.
Mar 09, 2013 | Music
The light on the end of the dock stays red. Battery when recharged turns green. When placed back on the dock, then the light goes back to red.
Turn your camera on and look at the battery life after you had it charging for a while. your rechargable batteries may be bad or getting bad. Try trading out the rechargeable batteries or try plugging in your charger on a different outlet at home
Mar 04, 2011 | Cameras
Cordless Battery-Powered Soldering Iron wont turn on anymore
You can replace the battery with other new batteries, that way, you can tell whether it is the rechargeable batteries or the iron that are faulty.
Mar 09, 2010 | Weller BP860MP Dual Heat Battery Powered...
Draining rechargable batteries;
Carry spare alkaline batteries - just in case...
Does the same symptom happen with alkaline batteries?
Lithium Ion batteries are 1.2volts
Alkaline are are 1.5volts
Rechargeable Alkaline batteries are 1.5volts
Perhaps you should switch to Rechargeable Alkaline batteries if the symptom goes away when you use alkaline batts...
Sep 17, 2009 | Samsung Digimax D53 Digital Camera
To recharge my rechargeable batteries, do I plug into the back of the console and the top of the battery pack, how long does it take to recharge
to recharge your rechargeable batterie you plug the holder that hold the batteries into the wall, then a green light should turn on. That should help you out! :)
It takes bout in hour.
But thats how mine work
Aug 07, 2009 | Nintendo Wii Fit - Balance Board + Game...
Camere jammed and wont turn off and retract
Install new batteries.....really! They will just up and die when your camera's on and then there's nothing else you can do. If you have rechargeables....swap them out for any fresh batteries just to close your camera...then put your recharged rechargeables back in. Or put them back in and recharge on your camera dock.
Mar 13, 2009 | Kodak EasyShare C613 Digital Camera
Cameras - No respond?
Try replacing the batteries.That's what my camera did when it just needed a battery replacement.
Jun 05, 2008 | Samsung Digimax S730 Digital Camera
Help with s630 Digital Camera
Rechargable batteries actually do not recharge the 100 times advertised. After maybe 10 times they are reduced in capacity noticably. For instance, new alkaline batteries will last me maybe 60 pictures, however the rechargables are only good for about 5. To test this try taking out the batteries, and put back in before you wish to try them, also turn off the flash if it is not needed.(flash uses a lot of power)
Apr 11, 2008 | Samsung Digimax S630 Digital Camera
Depressing my shutter button on my Fuji FinePix E550 causes it to turn off. When I turn it back on there is a no image message. Is it cheaper to buy a new camera than to have it fixed? Thanks for help
You just need new batteries. That's what the E550 does when the batteries get too low. Please get the latest rechargables. Many of the ordinary AA batteries won't last 50 pictures. Fuji also is rather poor telling you how to charge the rechargables. When the screen goes blue when you take a picture, you must use the camera's de=charging system before recharging--otherwise the rechargables will not take a full charge--that's what's likely happened to you!
Feb 15, 2008 | Fuji FinePix E550 Digital Camera
Ryobi Tek4 Professional 4-Volt Infrared Thermometer RP4030 Logo
101 people viewed this question
Top Ryobi Measuring Tools & Sensors Experts
JOHN LAPIER
Vuk B
ray gallant
Are you a Ryobi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
