Question about Snapper 7800785 - 2812524BVE 28" 12.5HP Hi-Vac Rear Engine Riding Mo
Snapper nearly dies when brake is released
Hi - new here. My church has a Snapper model 7800785 that has these symptoms. Cranks normally and runs great. When I am seated, trans in neutral, blade engaged or not, when releasing the brake, the engine RPM drops to nearly nothing but keeps running. If I rise from the seat, the engine will die completely. While the engine is running (although nearly stopped) I can engage the trans forward and reverse. When the brake is released the RPMs fall off to nearly nothing and the mower will lurch in that direction. Local dealer says the seat switch is good and they told me how to look at the connector and it looks good. Had a new fuel filter 2 months ago. I appreciate a suggestion. Thanks
  • 80 Answers
Sounds like one of the safety switches are going bad there is one on the deck it looks like a finger
Posted on Apr 14, 2014
Mower cranks and runs fine but when I release brake pedal, it dies. I have check all safety switches and they all have continuity when they are suppose to
Sounds like your seat switch isn't working. Operator presence (seat switch activated) is required when the brake is released & pro is engaged or your engine will shut down.
Feb 14, 2016 | Garden
Why does snapper rideing lawn mower stall when brake is relased?
Hi Jerry:
These machines have a lot of safety switches intended to protect the operator.
If no-one is sitting on the seat (activating that switch), releasing the brake will shut the engine off.
That's the first thing I'd be checking.
Hope this helps.
Cheers.
Nov 01, 2015 | Snapper Garden
I have a cub cadet ltx 1040 everything cranks and
bad safty switch on brake replace it says the red neck
Sep 24, 2014 | Garden
Normal performance 10 min of use then drags like brake on loses speedbrake assy gets hot unlock freewheel and pause relock will help run better for awhile
Hi, now there it could be one of two faults, the brake magnetic core is not releasing the brake after a period of time, it's breaking down , other-words it's dragging or the voltage from the controller is not high enough or not enough current , a controller fault...check the wiring going from the controller to the brake... now a simple test would be to remove the brake but still have it connected via the two wires and tape on to the motor now you must be careful here because the scooter will roll if near a incline etc...so you been warned !!!! ... does the scooter run okay now ?
I do repair brakes..
Regards
Rob
www.gewizrepairs.co.uk
Dec 29, 2013 | Pride New Mobility Celebrity 3 wheel...
My snapper nxt2346 engine dies when I release the brake
sounds like the safety switch, check and replace
Aug 31, 2013 | Toro Garden
Snapper mower
If the hand brake is on that will also kill the engine.
Oct 30, 2017 | Snapper Garden
Car cranks fine, go's in gear fine but when i mesh gas paddle dies out when i release it go's back to normal idiling
Usually a sign of a faulty throttle position sensor or low fuel pressure.
Those two things would need to be checked first.
Oct 12, 2012 | 1994 Buick LeSabre
Where is the safety switch for the brake on a snapper riding mower
it depends on the model you have a front engine it would be near the pedal on a rear engine mower it is near the rear axle
Jun 09, 2012 | Briggs & Stratton Garden
Snapper Mower hard to start/run
the choke is controlled by a rod that goes to the muffler it's a open or closed thing see a lot more problems with dirty carbs and the needle valve seats swelling from the fuel
May 28, 2012 | Garden
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Snapper 7800785 - 2812524BVE 28" 12.5HP Hi-Vac Rear Engine Riding Mo Logo
264 people viewed this question
Top Snapper Computers & Internet Experts
David Payne
David Payne
Are you a Snapper Computer and Internet Expert? Answer questions, earn points and help others
