Question about Kenmore 43042 Front Load Washer
205850 model motor
Will not spin out
My kenwood 43042 front load wash machine will not spin out and the motor smell like it burning. I just installed a new motor
Posted on Sep 19, 2013
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Older kenmore warsher, Model num 110.14202300. not drain or spin
If it won't drain or spin check the lid switch. If it sounds like the motor is running when in spin check the coupler between the motor & and the transmission will have to pull the motor to get to it.two plastic parts with a rubber piece between them.
Jan 02, 2018 | Kenmore Washing Machines
I have a sole motor from a front loading washing machine that i would like to use on the spin cycle only (for another purpose) but the wiring diagram is no where to be found. Which of the multiple wires is...
if you send me the diagram I can possibly give you the answer, as normally there is the driver pcb to consider or I will find you the best way to do it, please ask the web site for my email address as I don't know if Im allowed to publish it on this answer eric
Jan 16, 2018 | Frigidaire GLTF2940ES Front Load Washer
Machine does not spin,model no 3008 could you
modern washing macine motors don't have brushes they are what is called inductive not touching parts .
just doesnt spin ? or wont run at all ? hears a rule of thumb washing machine motors are very tough (usualy) unless a drum seal leaked causing corrosion or somthing mechcanical has gone (meaning you can't spin the motor with you finger ) then your problem is probably elsewhere ie...lid switch, cam control switch,... you get the idea
Good luck
Oct 09, 2009 | Washing Machines
Wiring diagram for electric motor Sole made in Hungary Model 205850 AC EL CL F 110V 16K RPM 110 volt"
The more I look at this motor the more I think that it is a stepping motor and not an AC motor... I could be wrong, but checking the windings and seeing the small Tach Motor on the rear leads me to believe that this is not a ac motor, but a stepping motor and is triggered from the programmer for rpm
Apr 30, 2009 | Washing Machines
Kenmore 417 Frontload Washer - Motor goes if I give it a push.
This problem drove me crazy. I thought the motor was bad after about a year and a half. Because the problem was intermittent and I could "force" the machine to work, I pulled the panel and listened to the sounds each cycle made, making a chart of what each sound meant to the cycle. I jiggled the wires at the motor and then followed them up toward the switch housing behind the cycle knob. When I jiggled there, I could recreate my problems. I found that the plastic housing to the switch control behind and below the cycle knob was not fully snapped shut, as the washer would go through the cycles, the drum would bump against this housing and cause the wires (inside) connections to jiggle, thus sounding as if the motor was not working. I removed the bottom panel, reaching up to the area behind the cycle knob, tracing the wires from the motor. I pulled the casing out (I had to cut through the rubber liner) and wrapped it with strong tape, and replaced it. I have not had a problem since.
Jan 03, 2009 | Kenmore 43042 Front Load Washer
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Sep 06, 2008 | Maytag Washing Machines
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 43042 Front Load Washer Logo
148 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
