Question about Garden
John deere 3032e has unwanted shut offs .
Driving fine sometimes but when warmed up shuts off every 10 min.
canbruce75
  • 1776 Answers
SOURCE: engine shuts off while driving
I would suspect a faulty EGR valve, but is the check engine light on? If it is, take the vehicle to an autoparts store and have them use a scan tool to retrieve the fault code(s) stored in the computer. Most parts stores offer this service free of charge. That will narrow the search for the problem. Sure hope this helped.
Posted on Jul 20, 2009
  • 112 Answers
SOURCE: I have a John Deere GT225. The hydrostatic drive
sounds like your linkage is disconnected, With the tractor off raise the seat and back panel (if possible) and work the shift and look for failing linkage.
Posted on Jul 25, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
  • 73 Answers
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
Posted on Oct 02, 2009
  • 3640 Answers
SOURCE: car shuts off while driving
if car shuts off while driving it could be a bad crank sensor. a bad crank sensor will shut car off while driving, then it will not start for about 10 minutes, when it starts it runs fine until it goofs up again. the popping could be the sensor for it controls timing along with the cam sensor.
Posted on Oct 03, 2009
John deere shuts off when mowing
sounds like you have sensor gone wrong.try to check what sensor you use thru your manual
Jul 17, 2014 | John Deere 1966 110 Lawn Tractor 7 Sprayer...
My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 6420 shutting off
Take apart fuel line around tank and blow out. Might also be something in tank that is getting sucked over the outlet. Clean out fuel tank
Feb 23, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
My 1979 111 john deere lawn tractor deck blades shut off
Sep 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Blade on John Deere L110 will not shut off
Check the cable that runs from the acuating lever to the tensioner pulley on your deck it could be broken or frayed. also check the plastic holder on the deck end of the pulley, it fits in a small groove in a brace on the deck and is held in place by a tractor pin. when they removed your deck to sharpen the blades they may not have re-connected it properly or the plastic holder may be broken and not allowing the proper tension on the cable. if your tractor is equipped with a PTO switch near the lever check the connections and the continuity of the switch...hope this helps.... ;-D
Aug 10, 2009 | John Deere Garden
Mower runs for 10-15 mins. then shuts off.
Check your gas cap. There must be a vent for the gas to flow joedog
Feb 26, 2009 | John Deere Garden
Mower runs for 10-15 mins. ands shuts off
I had the same problem on my craftsman 18.5 hp, the problem was in the choke, the spring was broken, and the choke was not free, replaced the spring and it is fine now. Check it out. Good luck.
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
