Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 1500 PRNDL keeps blowingand i dont know why
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 44 Answers
TRY ADJUSTING THE SWITCH ON STEERING COLUMN UNDER DASH AND BE CARE FUL WHILE ADJUSTING IT WILL START IN GEAR SO MAKE SURE IT IS IN PARK GOOD LUCK
Posted on Jul 14, 2013
On my ford freestyle gear indicator light how change it
Remove the PRNDL trim ring.
Remove the upper console panel.
Slide the lower shift knob bezel downward.
  1. Remove the bolt and lift up on the shift knob to remove.
Remove the lower shift knob bezel.
Disconnect the light bulb from the PRNDL bezel. an replace .
26002487-w0jffanovav232xjqcbliw5g-1-0.gif Don't think you need take shifter knob off . Just PRNDL trim plate an upper console plate . They should just pull up , use plastic trim tool to get it so you can get your fingers under an pull up carefully .
26002487-w0jffanovav232xjqcbliw5g-1-2.gif PRNDL trim plate
26002487-w0jffanovav232xjqcbliw5g-1-5.gif Light blub connector !
Dec 11, 2015 | 2006 Ford Freestyle
What does PRNDL error mean?
check the seliniod under the shifter mine was faulty so i got an electrician to by pass till part came in
Sep 11, 2014 | 2003 Ford Expedition
Key wont crank engine but crossing the starter it will crank
best post ever, for this failure. you win a prize !
that means the KEY line is dead.
that tiny wire on solenoid is a KEY line.
and can be interupted many a way
the car has autotmatic, the PRNDL switch failure. (try cranking in neutral)
i dont think any 91 has anyd immobilizers but some have alarms that cut this line.
i looked at your schematic. (no engine stated)
but the one engine has the very odd starter solenoid.
4 lugs, not 3 like normal
the key switch powers one side of solenoid coil
and the clutch or PRNDL switch grounds the other side. brown-yellow wire. if the PRNDL is bad, park or N location its bad.
try neutral and wiggle the shifter in both spots all A/T cars.
Jul 07, 2014 | 1991 Dodge Spirit
Starter will not engage
check all fuses. there are many for this circuit.
fuse 2 and 20 must be good.
no ! this is not and ASD function.
the starter is totally independent, (the EFI does not run the starter)
my wild guess is this as A/T slush pump car.
so as such has the PRNDL switch.
even IMMO unhappy allows cranking but cuts fuel and spark. via ASD
the Key switch sends 12vdc to the PRNDL
you try park or neutral.
you wiggle it, omg it cranks. PRNDL death deal (1million served)
this car has a starter RELAY, simple
12v to 2 pins, key on.
the PRNDL grounds the coil the relay closes, and the output 12v
goes to the starter solenoid.
there is no need to guess the FSM is here, read starting and schematics. bingo
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
see 8w-21-1 , the simple path there.
if the fuses are good
and you have 12vdc across the relay coil the PRNDL is good.
if the 12v is missing the PRNDL is bad.
assumes the ground to the PRNDL i good.
see 8 ways to crank here ,tricks, M/T rule on cranks....2 ways.
http://www.fixkick.com/nocrank.html#tricks
i just hot wire the starter solenoid and that cuts the problem in half
at the get go.... no fiddling about.
it already failed jump starts. and battery is good and charged, so..
hot wire it. grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr, ok starter is good.
but key line is dead.. 1/2 the work is gone. fail path know.
Mar 05, 2014 | 1996 Jeep Grand Cherokee
The sensor Transmission netural switch
M/T or A/T
we dont know what transmission you have.
on A/T the side if case tranny is PRNDL switch, this is it.
on M/T its screwed into the main 5 speed box.
Feb 09, 2014 | Jeep Cars & Trucks
Want to locate Transmission range sensor
this is easy, there are only 2 electrical connectors on trann
one is the shift soleniods , in side.
the other is the shifter. PRNDL, prindle.
the PRNDL is on the the lever that shifts the actual transmission
car is under warranty, why fiddle?
you shift, and the PRNDL switch simply tells the PCM what you did.
nothing more. it also runs the Reverse lamps.
alldata.com or any FSM for car.
or
2nd google hit. plain english , see part 20
http://www.microficher.com/2005-honda-cr-v-5dr-ex-ka-5at-at-left-side-cover-5at-exploded-view-diagram
btw , go to any dealer on line , click parts, and look at all parts
you can see all parts and buy them if need.
Dec 24, 2013 | 2013 Honda CR-V
PRNDL FUSE KEEPS BLOWING 97 1500
check wiring insulation or disconnect prndl and see if it clears
Jul 12, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
I dont know where thew shift indicator cable attaches on a gmc 1500 1994
ONE END ATTACHES TO THE PRNDL SWITCH ON THE TRANS. THE OTHER UNDER THE DASH RIGHT SIDE OF THE STEERING COLUMN TO A LEVER BY A SMALL BALL SOCKET CONNECTOR
Feb 22, 2013 | 1994 GMC Sierra
Prndl error
Transmission range sensor is bad $75 at dealer.
Dec 21, 2012 | 2003 Lincoln Navigator
My 2003 lincoln navigator wont start and the error message in the dash board keep saying..PRNDL ERROR PARK ASST..does anyone knows what that means?
check the relay #303 if its burned or damaged and you can buy it at an auto parts if that relay is not the problem check the rest of the relay just to make sure they are working properly hope that this can help with your problems
May 13, 2012 | 2008 Lincoln Navigator L
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
