Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
PRNDL FUSE KEEPS BLOWING 97 1500
PRNDL fuse keeps blowing and i dont know why
    New Friend:
Check wiring insulation or disconnect prndl and see if it clears
Posted on Sep 02, 2013
  • 462 Answers
SOURCE: keep blowing fuses under hood.
REMOVE THE FUSES ONE AT A TIME FOR EACH ITEM ON THE 50 AMP CIRCUIT. I WOULD START WITH THE POWER WINDOW FUSE FIRST. IT WOULD BE THE MOST LIKELY SOURCE OF A HIGH VOLTAGE DRAW. THEN GO ON TO THE WIPERS AND SO FORTH.
Posted on May 31, 2009
smarthome2
  • 1114 Answers
SOURCE: THE IGN A FUSE UNDER THE HOOD KEEPS POPPING
You have a serious short. The fuse is keeping you from frying the electrical system. Did you make any changes to the vehicle recently? Is it all stock electrical? If so, check the Ignition relay in the alternate fuse panel. If that does not work, post a reply and I'll help you dig further. Hope this helps
Posted on Jun 04, 2009
SOURCE: need wiring diagram for 1995 chevy 1500 silverado 305.
need a wiring schematic for a 90 s-10 blazer cut the wires to dist now cant find leads
Posted on Aug 24, 2009
SOURCE: my 95 chevy keeps blowing the ignition fuse
im having this same problem with my 92 k1500
Posted on Feb 26, 2010
  • 16 Answers
SOURCE: fuse for power doorlock keep blowing when i push lock but not when i push unlock
You have a ground either in the switch or in the wire going to the lock solenoid.
when you push the button to unlock power goes thru the wire and the solenoid
then to ground on the other wire that is grounded. when you push the button to
unlock, power is reversed, and goes to the grounded wire then poof-- the fuse
blows.
Posted on Nov 26, 2012
tRY ADJUSTING THE SWITCH ON STEERING COLUMN UNDER DASH AND BE CARE FUL WHILE ADJUSTING IT WILL START IN GEAR SO MAKE SURE IT IS IN PARK GOOD LUCK
Jul 12, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 05, 2012 | 1999 Chevrolet Prizm
Exactly what can blow the main fuse
Hi, Anonymous you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Main Fuse Blows The FZR Forum
View topic 92 FZR600 Keeps Blowing Main Fuse
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 24, 2012 | 1991 Yamaha FZR 600
My fuse in my car keeps blowing
thats the fuse for the cig lighter. make sure there is no change in there
Apr 18, 2012 | Chevrolet Cars & Trucks
I have a fuse that keeps blowing and the white letters are gone so i dont know what it goes to
you have some componet that has melted down contacts (it's hotwire is grounded) so every-time u turn on the key power is fed to direct short and the fuse blows.So look around at things that dont work.after fuse blows does motor still operate,keep it running and find out what doesnt work then check that component for melted,grounded wires...
Dec 27, 2011 | Cars & Trucks
Fuse #24 keeps blowing
If fuse #24 keeps blowing it is because you KEEP replacing it without diagnosing and repairing the reason it blew in the first place.
Please review the following articles by clicking the links below:
Where's The Fuse?
What Else Could Be Wrong?
Then a little info:
Fuse #24 protects the circuits for your PRNDL indicator in the instrument cluster, the PARK switch and/or shift lock actuator, and the circuits for the shift solenoids inside the transmission.
One of these circuits are shorting.
Aug 09, 2011 | 1997 GMC Jimmy
Toyota Camry 1994 Main Fuse keeps blowing
-if your fuses are blowing
-the problem is in the wiring
-because if too much amperage flows through the fuse will blow
-there's probably a short to ground somewhere or high resistance after the fuses causing it to draw more amps
Mar 19, 2009 | 1994 Toyota Camry
Fuel system fuse keeps blowing
where wire run to pump over fuel tank i thing you will find they are chaffed .use a lenth of twin flex and rewire it quickest and easyest
Feb 02, 2009 | 1991 Jeep Wrangler
BLOWS FUSES
If it blows fuses only after the remote voltage is applied, the amplifier likely has shorted output transistors.
Let me know if you have any other questions.
Aug 30, 2008 | Rockford Fosgate RF2002 Car Audio...
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
390 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
