Question about Sharp 32L-S400 32" TV
TV TURNS OFF BY ITSELF
While watching tv my tv turns off by itself after a couple of minutes. It's a regular SHARP 32L-S400B tv.
  • 132 Answers
Sounds like the Startup Relay is dropping out, you will need to replace it.
Posted on Mar 28, 2009
SOURCE:
Our Sharp GA864WJSA TV intermittently turns itself off for a few seconds, then turns itself on again. Please help???
Sharp Aquos problem - YouTube
? 1:41
www.youtube.com/watch?v=-EuJZ9NUf3Y
Apr 24, 2012 - Uploaded by rsimon24
So my tv is just turning off by itself, some people tell that is a software issue, others resistance hardware. Has .
Sep 12, 2015 | Sharp Aquos Televison & Video
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
SHARP 32L-S400B SHEARED OFF CABLE CONNECTOR FROM INSIDE TV TO CABLE .CAN IT BE REPAIRED INEXPENSIVELY?
I have the same problem. Do not have any idea on how to fix it without probable major expense. I have to connect cable box to RCA inputs which require the dvd player to connect with the front inputs...very inconvenient! Hope someone has an answer to this problem.
Sep 04, 2010 | Sharp 32L-S400 32" TV
My sharp 32L-s400b will shut off after it warms up and will not come back on until unplugged for a short while to cool down
What I can think of is either the main filter capacitor is dried up, I had a set that would stay powered on til it warmed up then shut off and the main filter cap was the problem. Or the tv could have a thermally induced shut down, or the circuit protection kicks in due to excessive voltage. A component is defective and excess voltage is happening and the tv shuts down to prevent excessive X-ray emissions or damage to other components. You should open up the tv, be very careful and if you don't feel comfortable, have someone with more experiance or a shop look at it. Look for any blown or burnt components. Also listen for any weird or funny noises inside the set.
Mar 12, 2010 | Sharp 32L-S400 32" TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv turns off while watching it stays off a couple
Sharp 60" DLP 1080i , while watching cable, the show blinks off and on. but if we play video games or watch DVD's it works fine. what is wrong?
Jun 23, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
TV Turns Off
You may also have a capacitor that is going bad or is on the verge of going poof. Anyhow, check for any leakage on the PCB and if you have a capacitor checker check all the caps. Visual inspection may find it as well...Good luck technician. GURU JAY
Feb 18, 2008 | Televison & Video
TV Turns Off
Good day.
Yuor TV has an issue particularly in the power supply section with regards to the loose components. This issue can be best addressed by having your units' circuitry be resoldered before it could damage some parts.
Response is higly appreciated.
chris
Jan 11, 2008 | Sharp 32L-S400 32" TV
Sharp 32L-S400 32" TV Logo
310 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
