Question about Hayward H-series Electronic Gas Pool Heater H300
Error code (LO)
Heater will run about 20 minutes at a time before shuting off and giveing Error Code (LO).
  • Hayward Master
  • 1,631 Answers
LO is simply informing you that the Heater is not sensing proper water flow through it! A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Posted on May 25, 2015
    Problem Solver:
  • 12 Answers
Could be either the pressure switch(tells the heater that there is suitable amount of water flowing the startup the ignition), hi limit switches, or low vent pressure(if you have a exhaust fan installed for the model. Easiest thing to try is to give the pool filter a good backwash. If this doesnt solve the problem, than the above electrical components need to be looked at and singled out
Posted on Jul 19, 2013
  • 61 Answers
SOURCE: Hayward H250 giving me a "LO" error code and does not turn on.
9 times out of ten this means that you have a faulty water pressure switch. It could also be a limit switch, or air pressure switch. Make sure the filter is cleaned, and all valves are in the correct position. Once you are CERTAIN that water is flowing through the heater, you will need to short each individual component to find the faulty one.
Posted on Apr 11, 2009
SOURCE: "LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Posted on Jun 07, 2009
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
  • 4 Answers
SOURCE: LO error message
On of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. Always make sure water is flowing through the heater at all times while checking the limits.
Posted on Mar 01, 2010
  • 4 Answers
SOURCE: my hayward heater gives a LO error when trying to
One of your limits is not working or not wired up. An easy way to check the limits - Water pressure switch, Hi limits, air pressure switch all of which have 2 wires going to them. Unplug one item and connect the 2 wires together ( paper clip works fine ) Then retest, if problem does not go away remove paper clip and reconnect wires and move to the next limit. The limits are located in the black plastic header. Always make sure water is flowing through the heater at all times while checking the limits.
AEG Lavamat Turbo 16830: error code E41. The machine will get approx. 20 minutes into a cycle then trip my mains circuit breaker.
It sounds more like a heater fault where the heater is shorting out. Try disconnecting the heater and test it with a meter, put one terminal from the meter on either of the heater terminals and the other on the heater casing, if you get a reading the heater needs replacing. If there is no reading then reconnect the heater terminals and do the test again this will test through the heater wiring, it will at least give you some idea as to where the fault is.
Mar 28, 2017 | AEG Washing Machines
I have a Whirlpool Duet Washer and I keep getting an error code "FL". Can someone please tell me what it means and how do I fix it?
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. Press the power button, and the washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Dec 15, 2016 | Whirlpool Washing Machines
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
LO error code
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Oct 31, 2012 | Maytag Washing Machines
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Error code e03
This is a code for a thermal fuse open. A thermal fuse is a saftey device I always call a wax switch, It's a switch held closed by wax and if it get's too hot the wax melts and the switch opens shuting the heater down.
Changing this out will not fix the problem. It's job is to keep the heat source from hurting the heater. In other words you have fire backing up into the heater outside the fire box. This can be a fan problem or sometyhing as bad as a broken firebox. You will probally need to get a repairman involved at least to find the problem. Good luck.
Feb 17, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Pool heater runs but the air coming out of the unit is cold.
R3 is not one of the actual error codes, but is part of the computer system. What you can try to do is reset the computer in the heater. First you will need to turn the heater off, then turn off the circuit breaker for the heater. Wait about 15 to 20 minutes then reverse the order, the circut breaker then the heater. Try and start the heater and watch the display panel.
If they R3 reappears, then the problem is the control board for the heater and it will need to be replaced.
Jul 02, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Apr 10, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H-series Electronic Gas Pool Heater H300 Logo
235 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
