Question about Plumbing
What are the standard sizes of your drainboard?
What is the best kitchen sink brand in India?
Kitchen sink is one of the important components of a Kitchen. Kitchen sinks are available in various size and designs. The standard for most kitchens is the double-bowl sink, which is 33-by-22 inches in size. There are lots of options in bowl configurations, including two bowls of equal size and depth, bowls of unequal width or different depths and sinks with one very large bowl and one small one that's primarily designed for the garbage disposal.
Single bowl sinks, which can be as little as 12 inches wide, work well in small spaces, and larger triple bowl sinks add convenience if you have enough room for them - some are more than 48 inches wide. And speaking of space, there is also the option of commercial-grade restaurant sinks that can be more than six feet long including drainboards. Sinks mount in one of two places - above the counter or below it. Above-counter installations are more common and are easier to install. Below-counter mounting offers a somewhat less obtrusive appearance and easier cleaning, but the sinks are more expensive and more difficult to install.
Below are top kitchen sink brands in India-
  • Kohler Kitchen Sinks
  • Blanco Kitchen Sinks
  • Houzer Kitchen Sinks
  • Swanstone Kitchen Sinks
  • Kraus Kitchen Sinks
  • CERA Kitchen Sink
  • Kaff Kitchen Sink
  • Nirali Kitchen Sink
  • Parryware Kitchen Sink
  • Blue Star Kitchen Sink
  • Hindware Kitchen Sink
  • Franke Kitchen Sink
Apr 16, 2018 | Home
Can a paper folding machine fold paper of different sizes or do they only work with standard size paper?
Most higher end folding machines are able to fold most standard size sheets of paper. You would have to check the manual or with the maker before trying anything too fancy. Mine works great with A4 and standard 8.5 x 11" papers.
Sep 24, 2013 | Office Equipment & Supplies
What is the standard size for a cheerleading megaphone?
There is no standard size. Maybe your town or sports team uses one size but there is no standard. They can be anywhere from seven inches to even twenty five inches
Jan 17, 2013 | Sport & Outdoor - Others
What are the standard bed frame sizes?
The are many sizes but the most common are: Twin 39X75 inches, twin extra-long 39X80 inches, three quarter 48X75 inches, full 53X80 inches, queen 60X80 inches, eastern king 76X80 inches, California king 72X84 inches.
Aug 23, 2012 | Acme Furniture
How should i do photo copy of legal size
oh legal size you mean 8 1/2 x 14 in?
if that's what you mean, first we have to identify if your machine is set US standard. there you will be able to copy legal size. Otherwise if JP/EU standard, you can only copy 8 1/2 x 13 as the nearest size.
please check it first
if the sizes on the scree you see are A4, A5, A3, FLS, then your machine is set to JP/ EU standard. If you see LTR, INV, LGL, LDR, then your machine is set to US standard, and just select LGL for you to copy legal size.
that's it
May 20, 2010 | Panasonic DP-8016P Copier
Irregular paper size
This possibility is not provided. You should solve a problem only manual presenting or format close to your but standard, but then zoom to correct the size on standard format. Spasibbo. Good luck
Jun 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copy orientation
Basicly, the check is smaller then a standard LTR size paper. The copier will only see it as a standard size. You will have to put a standard size peice of paper behind that check on the glass so it will read a standard size of paper.... The copier will not know that you are coping a check... They are not that smart..... Good Luck
Nov 11, 2008 | Office Equipment & Supplies
Stainless Steel Sink Question
s with most things, your stainless steel sink WILL scratch with use. However, over time as the sink ages, scratches will become less apparent and in fact blend into the surface. Minor scratches on the inside surfaces of the bowl may be blended into the sink by lightly rubbing a Scotchbrite pad in the direction of the finish grain. Be sure to rinse thoroughly with water and towel dry after this procedure, removing any particles left over from the Scotchbrite as you rinse.
Aug 27, 2008 | Advance Tabco Stainless 3 Compartment...
Plumbing Logo
423 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
