Question about Shuttle MediaDock IS73/320 LVD (DIGI99001192800) Hard Drive
Wharfedale ipod & subwoofer
My hifi is stuck on standby
  • 3,799 Answers
Your hi-fi is not part of a hard drive or a shuttle computer. If you have a problem with your Hi-Fi, it would be best to tell us the make and model and ask in the Hi-Fi or stereo section.
Posted on Jul 12, 2013
I need a remote control for this subwoofer
I would contact Wharfedale USA or Wharfedale.co.uk
Jan 31, 2014 | Wharfedale SW380 Subwoofer
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
Has anyone tried drilling the holes in the AMP Housing in their Infinity PS-12 to correct the Overheating/In&Out of standby mode?
I will suggest you dont drill the box. Insteady, you should open the box, and find heat sink matarials that you can attach to the power semiconductors to improve the heat draw from the factory heat sink.
see the link below for some heat sink on ebay
http://www.ebay.com/itm/Large-Aluminum-Heatsink-DIY-HIFi-Amp-IGBT-SCR-MOSFET-/250646348304?pt=LH_DefaultDomain_0&hash=item3a5bafc210
Nov 14, 2011 | Infinity PS-12 Subwoofer
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
Can I connect my floorstanders to wharfedale sw150 without any external amplifier, If so, how ?
What 'floorstanders'?
Its internal amp is for its own subwoofer ONLY, but if you use your own amp's full-range speaker-level outputs to feed two chanels entering the sub you can tag the 'floorstanders' onto the sub's speaker terminals as speaker wire extenders. Your amp will be powering the floor units.
I'd keep the sub separate and feed it LFE only if it was mine.
Feb 02, 2011 | Wharfedale SW150 Subwoofer
The cooling fins on my Wharfedale SW250 sub woofer are always quite warm, even when I have not used it for a couple of days. Is this Normal?
Sounds like it is on standby all the time. It only powers up fully when detecting an audio signal but will otherwise be in constant low power mode when not used.
Oct 30, 2010 | Wharfedale SW250 Subwoofer Subwoofer
I need user manual of Wharfedale topaz SW-12. Where I find it. thaks
WHARFEDALE Topaz SW-12 Subwoofe
connected to Sony STR-DE975 at the sub-
woofer out-put only hums, ??
thanks
Sep 06, 2010 | Wharfedale Topaz SW-12 Subwoofer
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
Computers & Internet Logo
67 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
