Question about Bryant Heating & Cooling
Where can I find schematic for bryant model rrl4-0175-pfv
I have a Bryant gas furnace model 394GAZ036125. After a heating cycle, blower motor shuts off, then cycles 2 times for approximately 2 seconds each cycle. What could be wrong ?
It's probably something going on with the limits. If the limits open, the control board assumes the unit has overheated, and brings on the blower to cool it down. Check all limit connections. As well as the connections on the board. Limits are the least expensive so you are right in changing them first, and there should be more than 1/ see schematic. If not the limits then it may be the control board but in 15-16 yrs I've not seen that. Might try(safely), wiggling the control wires at each limit, or tapping them with the end of a plastic handle, and trying to simulate a fault. Hope this helps!
Oct 19, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Where are the schematic for Bryant heating condenser model #986TB ?
most schematics are found on the inside panel where components are located
Jan 12, 2017 | Bryant Heating & Cooling
I have a copeland compressor model number cre4-0225-pfv. first what tonnage is it? and second i cant find a replacement number for it?
That is a 2.5 to 3 ton compressor and you can get one in many places. Try this one:
http://www.hvacplus.com/product/cre4-0225-pfv/127422/
Jun 29, 2011 | Heating & Cooling
What year is my Goodman Copeland Model # CR28K7-PFV-230 Serial # 07H93251H
The year of this Copeland scroll compressor is a 1993 model. 208-230 volt single phase.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Goodman Heating & Cooling
We have a Bryant unit and the air compessor outside still runs when the airhandler shuts off.
This could be one of many problems which could include a contactor malfunction, thermostat malfunction or some type of short in the control circuit.
Unless you are comfortable with electricity and the use of a multimeter and wiring diagrams/schematics, I suggest you call a professional regarding this issue.
Aug 22, 2010 | Bryant 462AJC021BA Air Conditioner
Bryant outdoor model # 567A-018E it humms like
open up it is probably the contractors. and easy fix you can push them down manually but be careful they are HOT- LIVE.if not sure call someone who does!
Jun 26, 2009 | Bryant 462AJC021BA Air Conditioner
Heating & Cooling Logo
63 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
