Question about Vacuums
Primary filter want turn - Vacuums
  • Vacuums Master
  • 17,326 Answers
What is the make and model number?
Posted on Jul 14, 2013
Where are the filters on my dyson
I can't be specific without knowing your vacuum cleaners model number.
The filters are in different places on different models. Some models have a primary filter in the dust compartment, some are on the intake of the motor. Some models have an exhaust filter under the dust bin. Some have filters inside the ball assembly.
Jan 09, 2017 | Dyson Vacuums
My numatic nvh 370, when I turn it on to use the air at it blow out smells, Why is that? Please thanks
If any moisture has entered the vacuum at any time then this will cause a musty smell. Does the primary filter have discoloration or a yellowy stain on it? this usually indicates moisture has been present at some stage. Replacing the filter may help or you can place a small sachet of air freshener beads (glade) in the bottom of the canister under the bag. This will give a pleasant smell whether vacuuming or blowing.
Feb 22, 2015 | Numatic Vacuums
My Hoover Elite Rewind just lost power while vacuuming and wont power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won't power back on?
Why is my hoover windtunnel vacuum cleaner shutting off?
Hi there! Sounds like the thermal protector is being activated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow the steps below to prevent the unit from shutting off.
1. Remove the hose completely.
2. Use a broom stick to gently loosen and clear hose of clogs.
3. Remove the bottom plate and brush-roll.
4. Use a wooden spoon or something similar to break up and remove any clogs from lower hose.
5. Check the primary filter behind the side grille. If it is dirty you may rinse it under running water and allow 24 hours to air dry outside the vacuum.
6. Remove the bag door. Clean the primary filter located on the vacuum under the bag. Rinse with water and allow 24 hours to air dry outside the vacuum. The primary and secondary filters should be replaced at least once a year.
7. Check that the bag is not full. If it is, replace the bag.
The vacuum will turn back on when it cools off. This can take up to an hour. Hope this was helpful!
Jul 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Why does the thermal protection keep shutting the vacuum off?
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Clean the filter as suggested by the owner's manual.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
Jun 28, 2014 | Hoover Vacuums
Why won't my hoover u6434 900 turn on?
Hello! The vacuum has a thermal protector sensor that will automatically shut off the vacuum when it is overheated. The vacuum should turn back on once it has cooled down. This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are steps you may follow to check your vacuum for blockages.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Hope this helps!
Jun 14, 2014 | Hoover U6434-900 Bagged Upright Vacuum
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
How to Troubleshoot hover and tunnel U6476
Hi! Below are step-by-step instructions for trouble-shooting your Hoover U6476.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
May 31, 2014 | Hoover U6476-900 WindTunnel Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
