Question about Health & Beauty
1250 mini turbo dual voltage hair dryer. i accidentally covered the back cooling vent and it overheated and shut off and now it wont turn on anymore. does it beed fixing or can it just cool off for a
It's an old fashioned hair dryer with heat coils inside.
    New Friend:
  • 49 Answers
Two different things could have happened, one is fixable, the other not.
- Hair dryers have a 'thermal fuse' that blows out if the dryer gets too hot. It's a safety measure to prevent fires. The fuse is buried in the heating coils of the dryer, it's a silver can with a wire on each end, and a black blob on one end. It is replaceable but it is NOT easy to get to. Digikey.com and Mouser.com sell replacements, they are called 'Thermal Cut Offs' (TCOs). About a buck each. You have to match the temperature rating of the old one, usually over 400F.
- The other thing is, the wires of the heating element itself may have overheated. They are very thin, and designed to heat up (duh). But they need air blowing over them to prevent them from burning out. Cover the back of the dryer, and the wires can overheat and burn out in just a few seconds. That's not repairable, so it's time to send it to the Great Hair Salon in the sky...
Posted on Mar 02, 2015
    New Friend:
    Problem Solver:
  • 5 Answers
I had on just like it and the same thing happened to me wat I did was I sent it to go fix
Posted on Sep 22, 2013
My kenmore dryer runs 10 minutes and shuts off and when you try to restart it it just clicks
Could be overheating and has shut down to cool off. Check lint filter and vents for unclogged conditions
Sep 13, 2017 | Kenmore Dryers
Freezer works fine, refrigerator not cooling model LTF2112ARB
Hello Gerard;
My name is Peter. I am a retired field service refrigeration technician.
You have a old unit, some parts are not available. Lets try to fix this anyway.
1.) You only have one source of cooling in you unit and that is your freezer. You are not getting any cooling air. If you reach in your fresh food section, in the top back is your air vent from the freezer.
Do you feel any air flow? No.
2.) Freezer Vents - In the bottom back of your freezer are either one or two vents that go down to your fresh food section. They may be covered with Styrofoam covers that easily pull off. Feel around the covers before removing. The vents may be plugged up with frost and ice. If this is the case, use a hair dryer to break the vent covers free. Once the covers are off, put towels in the back of the fresh food section to collect water. Either use a hair dryer or warm water to clear the vent.
3.) If you have a Belt: Ok the freezer vents were not blocked. You are going to have to remove the control panel cover in your fresh food section.
There is a belt that goes from your control nob to the air damper in the back of the control cover. This belt is not longer available. The belt opens and closes the air damper. If the belt is broken you may want to take a wide piece of rubber ban and join the belt back together with a stapler. Make sure the staples are flat. Better yet, try to make a new belt out of a bicycle tube.
Remove the control panel:
1.) Unplug the refrigerator or turn power off at the breaker.
2.) There are two screws on the side front of the control panel. One screw on each side. Pull the control panel toward you, it should drop down.
4.) Ok, the belt is good. The only thing left is the control assembly. With the refrigerator unplugged, remove the control assembly. Disconnect the two wire connectors and replace.
PART NUMBER: 63001358 - Cost: $78.00
Dec 14, 2014 | Refrigerators
Why my hair dryer doesn't emit hot air?
is the air coming out without as much force as before? may have dust or debrie clogging the fan. look at the back end unscrew the cap and check for , dust or anything like that.
Jun 08, 2014 | Helen Of Troy Vidal Sasoon 1875 Watt Turbo...
Jilbere Porcelain Series Hair Dryer.the blower doesnt work anymore,it happens when I was drying my hair.The motor smells normal not burned and I already check buttons for reset and no luck.
On the end there shouldbe a vent which houses the fan you should be able to open this by twisting ? Chech to see if there is hair/fluff/dust blocking this if it's not able to move the motor won't have anything to keep it cooled resulting in smelling burning as the caught up hair fluff and dust burn hope this helps :-)
Jun 08, 2014 | Dryers
I can turn on the tv and it's fine for about 20 min then the screen goes black with sound. I turn it off for a minute and it's fine for another 20 min. Like it's overheating.
It might also be a bad solder connection, short of checking voltages what I have done in this type of situation is with back off use a small fairly high speed fan - a hair dryer set to cool works, to cool areas of the boards inside to localize which board is causing this, with the set in failure, got it? it goes out cool it with a handheld hair dryer with air set to cool, when you find the spot where the problem is it will either instantly come back or try to.
Do it a few times to confirm which board is bad and locate a replacement board and swap it out.
Dec 15, 2012 | Proscan 47LB45H 47 in. LCD TV
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
Clothes dryer is overheating and then shuts off
Your vent pipe is probably clogged with lint. Clean out, and blow out, if possible, If the vent is clogged, the air cannot properly escape and all that heat stays in the dryer, which probably sets off some kind of themal protection switch, preventing the dryer from running until it cools down.
Oct 10, 2009 | Kenmore 73932 Gas Dryer
Overheating
sounds like you may have a plugged up vent or a bad motor. disconect vent hose from dryer and run a load of clothes if it works ok it is the vent. If the motor is shutting off and wont start untill it cools off youneed a motor. somewhere around 175.00 total cost would be a moderate estimate depending on which dryer could go to 225.00 depending on area and company that services.
May 28, 2009 | Dryers
Tv wont turn on only clicks and then flashes red timer light
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Health & Beauty Logo
1,515 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
