Question about Nil Freeway DVD 4383NBTi Navigation Multimedia Receiver with 4 3 Touchscreen Display and Remote Control
Installation guide for Freeway car audio model # 4383NBTi
Installed system but no sound. Need more instructions on wiring and installation
    Top Expert:
  • Nil Master
  • 12,223 Answers
Download from www. retrevo.com or www.fitness.manualsonline.com
or www.manualslib.com
God bless you
Posted on Jul 12, 2013
I am installing a DNA keyless entry system on my minivan. I bought it off of EBAY with NO installation instructions. It is pretty cut and dry as far as installing the actuators. My question is, What are...
After installing the kit just put a bulb on the desired wire and ground.It will show you the signal (if it has one).Smaller bulb better,because it will show you even short signals.Multimeter is better for this if availabile.
Oct 21, 2013 | 350 HV ESP Security System 350HV ESP
How to install a panasonic cq-c8303u
You might need a few things to install your radio. You will need a wiring harness, install kit, and instructions. You can find specific wiring harnesses and install kits at www.crutchfield.com and you can purchase instructions at www.sound-repair.com Hope this helps
Aug 23, 2011 | Car Audio & Video
We just installed the Kenwood KDC-X692 in our 1993 BMW 740il. The tuner works, but the CD has no sound and the AUX doesn't work either. I'm also confused on the bluetooth ready but lack of instructions...
i'm assuming you are going through an amplifier. if so it sounds like you are using the blue wire instead of the blue/white wire to turn the amplifier on. i can't really help you with the bluetooth though.
Jan 05, 2011 | Kenwood KDC-X692 Car CD/ MP3 Player
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
TRYING TO INSTALL REMOTE STARTER, INSTRUCTIONS
go to bulldogsecurity.com they have wiring color codes and locations for your vehicle.Also they list any special relays that you may need for factory security.
Please be sure to rate if this helps you out
Dec 29, 2009 | Astra Car Alarm And Remote Starter,...
I need installation guide for autopage rs-855 car alarm
I've uploaded the installation manual and wiring diagram to Yousendit.com. Here's the link:
https://www.yousendit.com/download/dVlvdFdVdVVrUmxMWEE9PQ
or
http://tinyurl.com/dhs964
Apr 18, 2009 | Audiovox Vehicle Parts & Accessories
Need help installing new thermostate
If you are replacing the same type of thermostat, the particular model you have can be used for heating and air conditioning using either gas or oil as a fuel source.
Even though it is low voltage, still turn off the power to your heating system and then you can begin. Label the wires that come off of the old t-stat with the letters on the back of the old thermostat they are unscrewed from.
Wrap the wires around something that is not metal, a pen, pencil or small piece of wood so they don't fall into the wall.
Install the cover ring (if needed) as shown in the instructions. I have included instructions from honeywell for this t-stat below. Install the wallplate, be sure it is level, use the diagram in instructions to see how wallplate should sit.
Use the wiring for the systems you have and the amount of wires you have depending on your mechanical systems. Set the heat anticipator for the type of system you have and place the t-stat on the wallplate. Turn your power back on and test both systems to be sure they are running correctly.
Fine tune using the instructions, your done. Total time to install aprox. 30-40 minutes including testing etc.
Click here for the link to instructions.
Any additional issues, please don't hesitate to ask.
Thanks,
Paul
My website
Jan 28, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Sir. good morning. i have a problem with my sound system. i tried so many times to solve. but i failed. please help me to instal sound card. i have p.4 system with vga card. request to please instruct me...
if your audio device is built-in, you need the utility CD, labeled as the name of your main-board. insert the CD select the audio driver then install it. sometime if you run the CD it prompt directly to a window which you can't install the driver by clicking to its button. if that problem occur, go to my computer icon, right click the drive that display the utility CD, then select explore, locate the audio folder then double click the driver and follow the onscreen instructions.  but if you have the sound card that plugin to your main-board,I'm sure it has a CD and the driver is on it, insert it into your CDrom and follow the onscreen instructions
Dec 12, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No sound, no volume controll icon in my computer
You need to install or re-install the sound drivers. To be able to download/install the appropriate drivers, you need to determine the brand/model of your motherboard and/or the sound card.
Pls post back with the brand/model.
Good luck and kind regards.
Dec 12, 2007 | Computers & Internet
Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Jan 17, 2006 | Yamaha DVX-S120 System
Nil Freeway DVD 4383NBTi Navigation Multimedia Receiver with 4 3 Touchscreen Display and Remote Control Logo
207 people viewed this question
Top Nil Televison & Video Experts
Are you a Nil Televison and Video Expert? Answer questions, earn points and help others
